Dear all,
I have a schematic from which I am building a circuit. There are two MOSFETS required for which I have found an equivalent part number (and datasheet) on Mouser to the one indicated on the schematic. I've posted the schematic and pinout side-by-side in the attached image.
Comparing the schematic with the pinout from the datasheet, I'm a little confused by the difference in symbol between the two. Can anyone guide me through which pins from the datasheet (D1, D1, S1, G1 for the p-channel and D2, D2, S2, G2 for the n-channel) correspond to the ones in the schematic? In particular, I am confused by the "hook" looking pin on the schematic which doesn't look like anything from the datasheet.
Any tips or pointers, even general ones, are gratefully received.
All the best,
Ryan
