I experienced same symptoms for around 13 years in my apartment block.
I can confirm if you exclude all other possibilities, then some kind of interference from power grid is causing it. The thing is that it must be on some fundamental level, so that you will not see errors in most of widely available software benchamrks and tests, maybe except some ultra detailed comparison of video output in place where this issue is present vs place where it's not present or some kind of PCI-E analyzers that costs thousands to see packet timing.
It is clearly something that affects system as a whole, not something that would disrupt just one thing in the system, like memory showing errors memtest on unstable overclock.
Confirmed multiple times going back and forth between two locations using laptop and PC, during one year. Also gone through multiple laptops and PCs through those 13 years trying to figure out what it is and ruled out hardware completely.
Most obvious symptom I discovered only last year is that timer measurements inside CPU-Z were glitching in a way it would do like microstops every x seconds that you could visually notice. It was at affected place.
While in unaffected place it would go flawlessly smooth like butter. No matter version of software.
I was going through regulatory institution to help me with that. I had evidence of AM interference affected regulated radio program. It was hard to convince old guys that hardware does not work properly. Second approach with AM radio interference also failed, as it was also available on FM, so it was non issue for them.
For couple of years I was suspicious about elevators in my apartment block. It's 1990s building, old elevators, TN-C electrical system. Then around the time those symptoms appeared it was at time they mounted VFDs to those elevators, while keeping old motors.
At first couple of years I wouldn't connect the dots, thinking something must have been wrong with my laptop, being too old or heating too much, so my journey through all tiers of hardware began.
Then sometime year ago housing association mentioned tender for replacing all elevators as they approached end of service life.
This year elevators were replaced to completely new ones, according to all new rules.
All symptoms are gone.
Now tell me how can a regular person prove that to anyone? Most people wouldn't event touch 1% of what I did to try to figure out what it is. From trying to measure it, to trying all possible filtering there is, to just being lucky in the end and thousands of euros less in wallet.
One thing is for sure. That not everyone might have the same thing, as people like to think they have what others do. You have to consider:
- if everything was ok before that
- when it started
- what has changed when it started (closest environment)
- rule out all software and hardware problems
Of course going with same hardware to other place and having no symptoms at all for prolonged period of time makes you suspicious, so it's also good approach if you have strong cues it can be such issues and save some time when you know your things with hardware good enough.
What doesn't help is lack of common way to measure it that in affordable way.
No one will want to spend thousands on hardware for measurement hardware, second apartment and get month of vacation just to test if monitor output is different x% on average on exact same automated scenario in same perfect lighting between two places.
It might be just like this thing with animation error posted above. People can tell, but there is not enough ways to measure some things yet, and if they are there, they are expensive.
For now it's a struggle for anyone who experiences it, as it's most probably something out of your reach to fix it on your own, unless you get lucky with source being too old and about to be replaced or it has other symptoms affecting critical functions, or some EMC people who will go above and beyond to find it (probably again about more money for their time).
I bet on supraharmonics, but again to prove it, it's another stack of money.
I'll also add that on my side trying out such things did not solve the issue:
- Medical grade isolation transformer
- Online UPS
- FN700Z filter
Only those stacked up made some singificant improvement but it was really unpleasant way to playing in a room that looked like hardware lab and noisy UPS, so it wasn't tested long enough.
