An issue that reminds me of yours occured here suddenly some years ago. I'm using an Microsoft BT mouse without an additional BT receiver, mainly to keep the USB ports accessible. Computer is an Envy NB with UHD Display. Over two years with a cadence of approx ten times or more a year mouse freezes at diplay and with a lag of 3 seconds the pointer jumps in centimeter steps. Unusable for hours.
My concern was, that anyone in the building uses an illegal unapproved BT device such a wireless headphone with too much RF-power or bandwith cosumption.
The only effective countermeasure against was, to jamm with a generator, set to sweep from 2.400 to 2.480MHz, AM mod and +13dBm feeding an log-per antenna directed to the floor below.
In near all cases the trouble ended after 10 minutes.
Knowing, that would be not a long term solution, i replaced the combo Wifi/BT card with the newer Intel AX201.
Issue never occured again since.
Small recap so we don't lose track:)
Lightbulbs: went from "normal" brightness", to dim, a tranformer was replaced and brought the brightness back, and now they are dimmer again.
PC or laptop on battery or plugged in exhibits the symptom.
For all we know there is a mad scientist two houses down the road polluting the neighborhood with "something" that's causing that.
I did use to have a tiny notebooks PC connected to my HF radio to decode and send morse. Decoding had no issues. Sending was another matter, with high-is SWR, and a 100W tranceiver 2 feet away from it. It would act sluggish, keys would appar "stuck" soemtimes it would lock up for the duration of the transmission, until the tranceiver was manually switched to receive, since the notepbook was too slow or in that "pause mode" unable to switch the tranceiver off.
Everything was in front of me so it "made sense". At least on of the 4 monitors on the other side of the room would do some watercolor effects, like they use to do dream sequences" in movies.
But that was a tiny notepook laptop next to a 100W HF tranceiver being flooded by RF.
I can't imagine soemthing external causing this amount of interference for this long a time (over 2 years now as the OP mentioned).
At the same time, don't be limited by my imagination.
Thanks for both replies; they are useful, so let me clarify a few important points and add missing context.
First, regarding the Bluetooth/RF interference example:
I fully understand that localized RF sources (especially in 2.4 GHz) can cause very specific and reproducible failures, like mouse freezes. In your case, the behavior was clearly tied to BT/WiFi and was resolved by replacing the radio hardware, which makes perfect sense.
In my case, however:
- The issue stays the same for all kinds of wired and wireless USB mice and keyboards.
- present with laptops running purely on battery,
- present with different PCs, monitors, and even TVs, including smartphones (when charging them).
– and persists when everything inside the house is disconnected at the breakers.
Because of that, I don’t currently see a single RF band or interface that could explain all observed effects in a consistent way.
Second, about long-term external interference:
I agree that a constant strong RF source affecting a whole neighborhood for years would be highly unlikely. That’s also why I’m not assuming a “mad scientist” scenario or some unknown transmitter nearby.
What makes my case confusing is that the issue has been present since the house was built. The distribution transformer for us was the same from ~2006 until its replacement in 2025. The only events that ever caused noticeable changes were actions on the power grid side (transformer replacement, switching events, emergency modes), and these changes were temporary. Except for the brightness of all of the devices.
I sometimes get spontaneous improvements lasting from 10 minutes up to a couple of hours:
The image becomes visibly cleaner (as if “wiped”), motion clarity improves, and mouse response becomes sharper. These improvements never last and disappear without any action on my side.
About grounding and day/night behavior:
Earlier there was a noticeable difference between day and night behavior.
After I implemented a local TT grounding for a single outlet (PC + monitor) in April 2024, the day/night difference disappeared completely.
The issue itself did not disappear, but its time-of-day correlation changed.
To be clear: I’m not claiming a specific cause at this point.
I’m trying to understand what class of parameters could change slowly or sporadically over time and affect timing stability across many digital devices, even when running on battery.
If you think this is not EMI, I’m absolutely open to that.
What I’m looking for is guidance on:
- what would be the next sensible thing to measure,
- what kind of disturbance could realistically affect multiple systems without causing outright crashes,
- and how to falsify wrong hypotheses instead of reinforcing assumptions.
