Have you had your main fusebox and interconnects insulation tested to various outlets?
Have you isolated the power, disconnected the copper at both ends, shorted one end together, then measured resistance between pairs at the unshorted end?
Probably better if you consolidated all your tests/checks and actual data into an easily readable document.
Its either a physical phenomenon or RF related for visitors to experience the same, and if as you say you have the same issues running off fully isolated batteries... that leaves RF. The fault clears when you travel.
The list might not be full, since there are many other things that I have tried, but there is not enough time to name all of them, since it's a lot.
1. Hardware & peripherals
Multiple PCs and laptops tested (different platforms, vendors, and generations)
Multiple monitors tested (LCD, high refresh rate, different panels)
Multiple GPUs, PSUs, RAM kits
Multiple mice, keyboards, mousepads
HDMI / DP / DVI cables replaced
Issue persists across all combinations
2. Software / OS
Multiple Windows versions and builds
Linux (Ubuntu)
Clean installs
BIOS/UEFI updates
GPU VBIOS updates
Chipset / GPU / USB drivers swapped
All OC/XMP disabled
MSI mode tested
VRR / G-Sync on/off
Frame caps on/off
Extensive stability tests (Prime95, OCCT, MemTest, Cinebench, and many, many others)
Internal telemetry (FPS, frametimes, clocks, temps, voltages) unchanged
The problem was occurring on the desktop when there are additionaly moving objects they behave abnormal.
I checked, as Dervu said, the timer measurements inside CPU-Z, and I can confirm that they were not acting; they were glitching in a way that it would do like microstops every x seconds that you could visually notice.
3. Network / ISP
Multiple ISPs (FTTH, coax, LTE)
Online and offline behavior is identical.
Router connected/disconnected
Ethernet connected/disconnected
4. Power sources
Online double-conversion UPS (online mode)
Online UPS disconnected from mains
Battery power stations (pure sine)
Isolation transformer
Autotransformer (Variac)
EMI/RFI filters: Industrial EMI filters (including EMSBI FZP-125-1, 30 kHz - 18 GHz range)
Ferrites on power and signal cables
Different sockets and circuits
Result: Symptom persists even fully isolated from the grid.
5. Electrical observations (measured)
Neutral-to-ground voltage fluctuates from ~0.1 V up to 5–10 V under load.
Ground-neutral resistance varies from ~4 Ω up to >450 Ω.
Neutral behaves worse than local ground
DC components detected on phase and neutral during outages
AC voltage near zero during outages, DC current still present
Changes observed after distribution transformer replacement
Day/night behavior disappeared after adding local ground reference (TT, single outlet).
6. RF/EMI
All household devices were disconnected, and there was no change.
Router and networking gear removed, and there was no change
The issue persists on battery.
RF monitoring performed (no obvious narrowband source detected)
Behavior similar to other independent users in different countries
7. Reproducibility
The same hardware behaves perfectly in other locations.
Returns immediately when brought back
Everyone who visited my place observed the same problem, which eliminates internal factors completely.
Problem present since building construction (~2007). Sometimes the problem was even worse; it all depended on the electricity company and their changes around the transformer and its neutral.
Improvements occur sporadically for minutes to hours, then disappear.
8. Correlated reports
Multiple users report identical symptoms:
delayed input without FPS drops
“heavy” movement feeling
worse at higher refresh rates
Mouse feeling heavy, sluggish, floating on ice, not precise, not snappy
Keyboard feeling nonresponsive, with visible delay even when typing in Windows
disappears when relocating with the same hardware
Reduction in overall image clarity.
Ghosting: the remaining trail of moving objects.
Image splitting during sudden mouse movements.
Open technical questions
Which external electrical parameters (neutral drift, common-mode noise, reference instability) can modulate timing/jitter without visible errors?
What mechanisms could affect display synchronization without altering internal mechanisms?
If someone believes this cannot happen:
Please explain why the same system behaves differently under different electrical reference conditions while reporting identical internal states.
That is the unresolved point.
