10mohms per volt
The Fluke 83 should have an input impedance of about (but not precisely) 107 ohms, or 10 Megohms, or 10M for short. So ohms-per-volt depends on range.
Modern DMMs have the same input resistance regardless of range.
should of said megga ohms,its to take readings on a bradley ct417c that i am trying to repair,its from 1965,in the service manual it calls for a valve voltmeter of at least 10 megga ohms per volt,so as not to load it i pressume.?
