Yesterday a friend brought a broken TV, obviously bad power supply (standby LED not lit, doesn't turn on). A voltage check confirmed that the the main voltage is missing. The secondary of the SMPSU has three diodes (SB5B0: 5A, 100V, Schottky) in parallel for the main voltage. Actually there are four on the PCB, one unpolulated. One failed short and the fault also released the magic smoke of the SMPSU controller (integrated MOSFET) and two resistors (current path to ground for the SMPSU controller's MOSFET). A quick search showed that Vestel, the manufactuer of the SMPSU, is known for that problem. Of course there's also a video:
