Now you are saying that in order to have a problem, you FIRST need to have a faulty part, THEN that faulty part will cause further problems.
I wouldn't consider a diode with an unusually low Vf a faulty part. Under normal circumstances, low Vf would be a highly desirable characteristic.
I recall someone who needed a 1% tolerance resistor. He didn't have any of those on hand, but he had lots of 5% resistors. And figured that since tolerance is a range, at least some of them would be 1% or less. All he had to do was test until he found one.
He was a bit surprised to find them all near -5% or +5%, with NOTHING in the middle. Apparently the manufacturer was using the same idea. They were all tested, and those with better tolerance were labeled and sold as such, at a higher price. The automated sorting was presumably cheaper than running a separate manufacturing process to specifically produce precision resistors.
What if diodes undergo a similar sorting process? With all the "unicorn" (low Vf) diodes removed and sold as a different part, then that would be awesome for running them in parallel. And you might do so successfully, and repeatedly. But suppose the manufacturer ends up with more low Vf diodes they can sell, and decides to temporarily skip the now unnecessary sorting; selling all the diodes regardless of spec as plain 400X series. You try paralleling these, and what worked many times suddenly doesn't.
And it would be no one's fault but your own. You broke the rules, using a part in a way that is technically questionable. If it's for a hobby project, chances are it's no big deal; I've done my share of rule bending there. But if it's for a product, and many products start blowing out in the field, you're in big trouble.
Then there's recommending something that's technically questionable to others. As a general rule I try to avoid this. On occasion I have not. There was one case where I suggested something, for which there was some risk, but on average the reward outweighed it. I explained all that based on my own personal experience, expecting it to scare most away, but surprisingly people tried it en masse. Turns out that while the reward still outweighed the risk, the risk was much higher than I'd represented. Fortunately most people didn't blame me for their losses, but I still feel responsible.
