What are you using this for, anyway? Do you have an application in mind, or..?
Variable cut/boost is a quite common thing (e.g., audio), but the closest application for "variable slope" would be something like, compensating for transmission line losses, where the attenuation of a long transmission line goes roughly as sqrt(f). Ionic diffusion is another example (e.g., battery terminal voltage versus current and time), among many other things.
Line compensation of course was solved a great many decades ago, by fellows such as Zobel. Typically, a variable network is used, to adjust the gain and impedance matching, at one frequency; an array of these networks are used to compensate the full frequency response of the system.
The peculiar thing is, those phenomena are all about high frequency losses, and compensating for them usually means adding loss at low frequency to compensate for it (since a passive network has no gain). So it's strange to have interest in an intentional "diffusion" filter, or indeed, any degree between there.
The mathematics concerning fractional order filters, by the way, is fractional calculus, a subject with (as far as I know) relatively little use, and not very well known. But if you are familiar with the rules of calculus, then you'll remember the integral of a power:
Integral x^n (n != -1) = x^(n+1) / (n+1) + C
That is, up to a constant factor, the only difference is incrementing the exponent.
Well, supposing there were such a thing as a "half integral", it should have the effect that the exponent is incremented by half, instead of one. (The constant factor might turn out to be irrational or complex for things to work out, but that's okay, as long as the second half-integral turns out the correct full-integral result.) The half-integral of 1 is sqrt(x) (give or take a factor, and constant of integration), or the half-derivative of x.
The transfer function of a lumped constant network, is a rational equation p(w) / q(w), where p and q are polynomials (i.e., a sum of integer powers of w). So you can't get irrational terms like sqrt(w) unless you apply fractional calculus.
So that's the kind of thing you're asking for, here. Almost. It's actually even worse than that, because you're not even asking about just a "half integral", or even a rational fraction, but a real valued fraction: continuously adjustable between 0 and 1, say.
So, analytically speaking... it's all kinds of a wonderful clusterfuck of mathematical abominations. I bet you weren't expecting that.
And, so, it might be an interesting problem for a mathematician to play with -- in general, functions with non-integer powers are non-causal (nonzero for t < 0) or complex (especially for t < 0), which real signals can't be, for obvious reasons. The first challenge is restricting the function to make it behave, without making it harder to work with; then trying to synthesize a circuit that exhibits that transfer function (probably using a lot of dependent components). As for producing an approximation with discrete components (even one with synchronized variable-gain amplifiers), good luck with that...
(I've gone into a little depth on this, partly to explore my own knowledge and curiosity, and partly to give you an idea of how many subjects your query touches on -- which it turns out is more diverse than the usual electronics question, even if you didn't intend it to be!)
