Author Topic: Variable Frequency Current Source ?  (Read 2290 times)
Offline alin_imTopic starter
« on: June 29, 2017, 05:59:14 pm »
Hey guys,
Can I use a function generator as a variable frequency current source ?
If yes, how ?
I want to model a photodiode to test a transimpedance amplifier and I need a variable frequency current source  and a capacitor in parallel. The frequency rage is between 10 - 100 MHz and the current between 10 - 100 uA
Alin I.
One man's 'magic' is another man's engineering. 'Supernatural' is a null word. - Robert A. Heinlein
Offline alm
Re: Variable Frequency Current Source ?
« Reply #1 on: June 29, 2017, 06:18:00 pm »
Sure, a voltage source in in series with a sufficiently large resistor (compared to the load) behaves like a current source (Thevenin/Norton). However, given the frequencies involved and the currents, I see problems.
To have a decent amplitude accuracy at 100 MHz, you would want your load impedance as seen from the generator to be close to 50 Ohms. This would require a transimpedance amplifier input impedance well below 5 Ohm, but would require voltages down to 500 uV. And obviously the capacitor in parallel will screw up your frequency response (depending on the value). So I doubt it would work particularly well.
Maybe if you calibrate your system over its frequency range. And regulation will not be amazing due to the low source impedance. Maybe coupling the signal through a transformer could improve matching and regulation?
« Reply #2 on: June 29, 2017, 06:27:41 pm »
My generator and my input impedance are 50 ohm, I was thinking of using a 1V peak to peak and a 10 kohm in series to obtain 100 uA current source, do you think it would work ?
« Last Edit: June 29, 2017, 06:33:47 pm by alin_im »
Offline alm
« Reply #3 on: June 29, 2017, 06:59:35 pm »
Only if your cables are extremely short or you do not care about voltage accuracy. Try it: connecting the generator to a 10 kOhm resistor with a coax cable. Then vary the frequency and observe the voltage at the 10 kOhm resistor with a 10x scope probe. The behavior will be very similar to an unterminated transmission line, since the impedance of the 10 kOhm resistor is very large compared to the 50 Ohm impedance of the generator and cable.
The following users thanked this post: alin_im
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #4 on: June 29, 2017, 10:30:43 pm »
You could always terminate the coax with 50R right next to the input of your DUT and just connect a 10k resistor from the 50R terminator and DUT input. The additional 10k termination is barely going to affect the 50 ohm termination.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline alm
« Reply #5 on: June 29, 2017, 11:01:04 pm »
True, that would definitely help the termination issue.
