I'm researching QFN parts for a potential project, and I'm concerned about reflow soldering with these components. According to some datasheets, the exposed pad on the back of some QFNs have pad vias in them, mostly it seems for either heat dissipation or ground. They seem rather small (typical drill size of 0.254 mm diam.), but how would you make sure that the part holds and that solder doesn't flow to the other side? Are there any tricks to it, or is it not a problem if the holes are small?
