Hello All!
This is my first post after joining your forum, and it is regarding an instrument type that I have no experience with, and it is old clunker to boot! I hope the question is not too dopey but if it is... apologies.
The unit is a Telequipment Oscilloscope Type S54
The Specs I have found state it is 10MHz Bandwidth, 400 Vdc + Max Input, Single Chanel.
Not sure if relevant but has a Y Axis selector for 1x/10x gain on panel.
It seems generally operational (?) But I have no probe, or signal generator yet.
I will only playing with this on Audio components and circuits. Low voltage stuff (no valves/tubes) until I learn a thing or two.
Question: Can I use any Probe up to the 250MHz ones I see about, or do I need to find a 10MHz unit? The lowest MHz 'cheapo' unit I have come across is 20MHz. The higher MHz probes give more choices and qualities but I am afraid they may not work at the rated MHz, and they are not 1x/10x selectable but seem fixed at 100x
Thanks for any advise/comments
Simon
