Author Topic: Visualising USB 2 High Speed (480 Mbit/s) on an oscilloscope  (Read 2807 times)
Offline JustAnotherGuy999Topic starter
  • Country: ma
« on: February 25, 2016, 07:24:21 pm »
What is the minimum specification (bandwidth, sample rate,memory depth, number of channels) of an oscilloscope to visualize USB 2 High Speed Signals.
PS: i posted this question on many forums, and i either got blocked, or i don't get an answer.
Is there an international law preventing people from visualizing USB 2 High Speed signals on oscilloscopes?
its just usb 2 not usb 3, come on
« Last Edit: February 25, 2016, 07:26:57 pm by JustAnotherGuy999 »
Offline marshallh
    • retroactive
Re: Visualising USB 2 High Speed (480 Mbit/s) on an oscilloscope
« Reply #1 on: February 25, 2016, 07:46:57 pm »
at least 2-4x the bandwidth (0.48gbps) so 1ghz to even see the signaling, 2ghz or 4ghz preferred.
Verilog tips
BGA soldering intro
  • Country: ma
« Reply #2 on: February 25, 2016, 07:55:11 pm »
thanks
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: February 25, 2016, 08:25:26 pm »
1ghz bandwidth, 4gs/s and deep memory. and get a machine that can run protocol analysis.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #4 on: February 25, 2016, 08:33:27 pm »
An "if you have to ask the price, you cannot afford it"-grade oscilloscope.
USB is differential, so either a diff probe, or a math channel. A protocol analyzer that is able to trigger would be helpful too.
Maybe try renting the equipment.
Offline John_ITIC
  • ITIC Protocol Analyzers
    • International Test Instruments Corporation
« Reply #5 on: February 25, 2016, 10:47:17 pm »
Do you want to visualize the analog voltage or the packets sent on the link? For the latter, you'll need a USB protocol analyzer. I design and sell such units.
Pocket-Sized USB 2.0 LS/FS/HS Protocol Analyzer Model 1480A with OTG decoding.
Pocket-sized PCI Express 1.1 Protocol Analyzer Model 2500A. 2.5 Gbps with x1, x2 and x4 lane widths.
https://www.internationaltestinstruments.com
  • Country: ma
« Reply #6 on: February 25, 2016, 11:01:10 pm »
Yeah i want to visualize the analog voltage
Offline gslick
« Reply #7 on: February 27, 2016, 01:33:04 am »
USB electrical specification compliance testing is probably much more involved than what you are looking to do, but you still might find some useful information in some of the compliance test procedure documents available here for some of the major test equipment manufacturers:
http://www.usb.org/developers/compliance/electrical_tests/
