Hello! On my desk is a desk-lamp and a 3D-printer ("Ender"). The moment I switch the lamp on or off, many times the 3D-printer crashes and restarts. The desk-lamp is a "Class II appliance", meaning it does not have a earth cable. The VoltAlter function of my multimeter, which senses AC voltage, beeps at 50 cm distance from the desk lamp (off), which to me indicates a nonexistent shielding. My theory is this: the unshielded cable of the desk lamp makes its metallic arms act as antenna. When the lamp is turned on/off, change of current increases that electric field and the 3D-printers mainboard, which does only have a plastic case, picks up that field and overloads/crashes. I omitted that other devices on my desk, for example a lab power supply, also at times cause the printer to crash at turn on/off events.
Is this reasonable thinking? I also wonder if there is a elegant solution. At the moment I am thinking about a DIY metal enclosure for the printers mainboard, that seems best, or am I missing something?
