Author Topic: what a screwdriver recommended for a man passionate about electronics?  (Read 3710 times)
Online BentaTopic starter
Hello, I'm Horst and I live in Saxony  :)
I work at the undertaker, but my hobby is electronics; i try to repair electrical devices, 99% of the time I don't solve the problem, but that's okay
Men usually read football magazines  :-//
but there are men who prefer to make love with electrons  ^-^
My equipment is: soldering station, two multimeters, bench power supply.
I'd like to start a seductive relationship with a screwdriver..   :palm:
I don't want to spend too much, but I don't want to buy the worst...
For example the model PB Swiss 6100 is ok for beginner man? or better Wera 917 SPH?
Other brands on these prices?
Do you have any advice for me? i am in your hands...
thanks
Horst.
Offline tkamiya
Re: what a screwdriver recommended for a man passionate about electronics?
« Reply #1 on: September 21, 2020, 11:43:37 pm »
So....  you are passionate about screw drivers....  huh?
Anywho...
What size are you needing?  Tiny, small, large or magnum?  Electric or manual?  Ultra thin or....  :-DD
I'm somewhat disappointing with Wiha.  Tips were not as well construed as the price suggested.  It's not hardened enough.  Few uses, all critical edges were lost and started slipping.  All kidding aside, I really wasn't impressed with Wera.  As to recommendations, I don't have any.  I had a fair luck with Chinese made kind.  Not the absolute cheapest kind but good 10 to 20 dollars for a set.  I just don't expect much from them (or any one of them), and as the points dull, I just replace.  You know, stamina isn't there.
« Last Edit: September 21, 2020, 11:45:13 pm by tkamiya »
Offline atmfjstc
« Reply #2 on: September 22, 2020, 12:10:18 am »
It's the other kind of charge carriers that might be more appropriate for this application, methinks...
Online jpanhalt
« Reply #3 on: September 22, 2020, 12:10:25 am »
You will fall in love with a Reed and Prince (or Prince and Reed) screwdriver.  Only someone truly passionate about cross-headed screws will be able to identify it.
https://chapmanmfg.com/products/reed-prince-frearson
Also known as a Frearson screwdriver, but real tool lovers call it by its real name.
Online Zeyneb
« Reply #4 on: September 22, 2020, 12:35:46 am »
Thanks for pointing out you're male. That totally changes the recommendations I had in mind.  ;)
Go for the unbreakable ones that are used in space repairs. And since you're male don't cry if you run out of budget to do anything else on your electronics hobby.
goto considered awesome!
Offline WattsThat
« Reply #5 on: September 22, 2020, 12:51:28 am »
I’m not sure which is worse. When my tool jumps out of the slot or when my tip breaks off  :palm:
Offline bdunham7
« Reply #6 on: September 22, 2020, 01:01:44 am »
Ideally screw....drivers...should be free.  However, if you are unable to get free screw....drivers, definitely go for expensive.  Cheap screw...drivers are hazardous to to your health and safety.
I'd recommend Knipex or Stahlwille.
Offline coppercone2
« Reply #7 on: September 22, 2020, 01:25:57 am »
wiha bit kit for 50$ with the extension will get you most stuff
I recommend taking care of it (build a block of wood that you put the bits in that is solid) and take care of them with oil.
Mine got rusty because of a corrosive flux spill, I actually took the time to wire brush every bit then clean it up with a diamond sharpening stone (lap) on ever facet. Don't keep buying screw drivers. I used to use a vice grip for screws
https://www.ebay.com/itm/Wiha-Tools-75992-Esd-Precision-Screwdriver-Set-Combo-27Pc/223757822334?epid=15019974499&hash=item341901697e:g:xRoAAOSwG69d1DqT
Try saving money on screw drivers so you can buy nice stainless screws for projects
If you want to restore rusty bits, keep in mind you can put them into a screw driver backwards and gently brush the back side, being careful not to fling the bit. '
If you are interested in electronics, and not mechanics, I recommend you clean every mechanical tool you can so you have a respectable project budget (a wire wheel can make you thousands). If you have a deep interest in mechanics, you will find damage that annoys you and is difficult to repair so it makes more sense to buy new stuff.
« Last Edit: September 22, 2020, 01:37:18 am by coppercone2 »
Offline Gregg
« Reply #8 on: September 22, 2020, 04:27:40 am »
For a serious screwdriver fanatic, only the best and sturdiest will do when the going gets tough.  I recommend the Wera 072017 hammer impact screwdriver set.   :popcorn:
https://www.amazon.com/Wera-05072017001-Impact-Driver-Pieces/dp/B0156CJJFI
Offline Gregg
« Reply #9 on: September 22, 2020, 04:51:07 am »
I just remembered the perfect screwdriver for your purposes; the Rosco Two Fister. Unfortunately it is no longer in production, but a diligent search of FleaBay might find a shining example for a very reasonable price; especially considering the ultimate utility provided by keeping both hands busy while fondling it.  :-DD
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #10 on: September 22, 2020, 06:38:54 am »
I really like the shape of Wera. I bought a Kraftform Kompakt 20 Tool Finder, ideal for around the house stuff.
And the Wera Kraftform Kompakt Micro set for inside devices.
Online tszaboo
« Reply #11 on: September 22, 2020, 07:08:56 am »
Here is my obligatory comment, to make this thread go 40 pages long.
I think you should try Pozidrive, it is better than Tektronics.
« Last Edit: September 22, 2020, 06:38:36 pm by NANDBlog »
The following users thanked this post: AndersJ
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #12 on: September 22, 2020, 07:21:17 am »
is like asking which one is the best? skinny, or fatty? whitish blackish or brownish black head red head etc... if you really in love you should try them all :palm: for me the best one is the cheap one because i can afford to buy many of them after i broke another one.
Offline Daixiwen
  • Country: no
« Reply #13 on: September 22, 2020, 07:53:48 am »
Just buy a hammer. Any screw can be turned into a nail if you hit it hard enough
Offline capt bullshot
« Reply #14 on: September 22, 2020, 08:06:02 am »
Dear Horst
I'd recommend this one:
It's no so good at driving screws, but will open bottles of beer. This is really useful for watching TV, especially these soccer games.
Offline Kjelt
« Reply #15 on: September 22, 2020, 08:12:30 am »
Is this serious?
If so, best sets I got the last years is the Wiha system4 for small things like electronics
and the Wiha system 6 for larger things.
Why I love them is because they stick together in a nice box or pouch and you never have to search in your overcrowded drawer to find the right screwdriver. You just know it is there.
And they fit really nice in the screws.
Offline HackedFridgeMagnet
« Reply #16 on: September 22, 2020, 08:39:22 am »
Had a funny experience buying a set of electronics Wiha screwdrivers for my sons birthday.
He was building his first PC.
I looked around a few places but found a set on Amazon that seemed to suit. There was about 20 Wiha sets IIRC.
When I went to purchase the cart, Amazon told me that I had purchased the exact same set 4 years before.  :palm:
Went into my workroom and there it was hiding under some stuff, I had forgotten I owned it.  :palm:
So I gave it to him second hand, what's the issue, at least it wasn't late
  • Country: my
« Reply #17 on: September 22, 2020, 08:52:30 am »
Is this serious?
too much price for the same thing... ;) i dont have objection, if you can afford it why not? but its like marrying Pamela Anderson vs marrying someone on the street that looks alike Pamela Anderson... here is what i currently use.. https://shopee.com.my/-Ready-Stock-MARKSMAN%C2%AE%EF%B8%8FII--36pcs-Screwdriver-Set-i.102586968.3543345849 the eqv price shown is only $10... i have something similar but smaller and cheaper earlier that broke due to its plasticy construction that hold the bits, but the bits are still useful because they are metal, so i keep them but havent yet a need to dig them because the Marksman has more than what i currently need (and Marksman sounds good too :P) if someone dont like all in one driver handle that fits every bits, this each handle for each bit probably can be loved, https://www.ebay.co.uk/p/2255389832 but i dont kind of like it since it requires too much space to store, ymmv. ps: now i think i want to be in love with this type https://www.wiha.com/nz/en/tools/multitools/interchangeable-blades/wiha-system-4/?p=1 since the bulge that hold the bits sometime blocking the bits from entering a deep hole screw, got to find one for stock..
Offline PA4TIM
« Reply #18 on: September 22, 2020, 09:02:57 am »
I suppose you are talking watch-maker size. I have a Proxxon set for like 10 years now, use them daily for my work. (Hex, torx, philips, straight) Better quality as the small Wiha set I have too. I have a few bit-sets with small bits for the more exotic types.
But I bought an ifixit bit set a few months ago and since then I use it for everything because I love the handpiece and the bits are good, bought it mainly because I often could use a flex extender and did not had one.
Full size I have 2 sizes posidrive, 3 sizes philips, 3 sizes straight. I also have a few drivers with an extra-extra-long shaft.
If you plan to work on imperial stuff you need a good set of imperial hex and torx
Offline mayor
« Reply #19 on: September 22, 2020, 10:33:41 am »
Hahah, the title. Good one!
Online jpanhalt
« Reply #20 on: September 22, 2020, 11:07:49 am »
There is, of course, another world of screwdrivers that go with electronics:
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #21 on: September 22, 2020, 12:57:09 pm »
Yeah, the similarity is amazing.
Offline TimFox
« Reply #22 on: September 22, 2020, 02:37:11 pm »
The Robertson square-drive screwdriver is the choice of real men.
Offline HB9EVI
« Reply #23 on: September 22, 2020, 02:44:15 pm »
I'd go with the hammer too; if there isn't any other tool than a hammer by hand, every problem starts to look like a pin ;)
otherwise my choice is Wiha
Offline Kjelt
« Reply #24 on: September 22, 2020, 02:49:17 pm »
That is a bad metaphor IMO, P.A. has an extremely short usability, while once spent a bit more money on a good set of screwdrivers you can enjoy it the rest of your life and it stays as good as the first day  :)
