Author Topic: What Can I Improve on my PCB Design?  (Read 1178 times)
Offline electromanTopic starter
    • n/a
« on: October 09, 2024, 02:10:13 pm »
Hello,
I'm new to PCB design and needed to create one for a project I am doing. There are I2C communication lines and a couple other power things. I have a couple questions:
Will disorganized tracks cause interference with the I2C protocol or any other protocol?
Is there anything that looks like it could cause issues besides that?
Attached below is a picture of the PCB,
Thank you!
Offline PGPG
Re: What Can I Improve on my PCB Design?
« Reply #1 on: October 09, 2024, 03:19:03 pm »
Will disorganized tracks cause interference..
One of important from interference/disturbance point of view is having continuous GND plane at your PCB.
I have posted at KiCad forum some links about PCB design worth reading in my opinion:
https://forum.kicad.info/t/decoupling-capacitor-via-placement/25132/14
https://forum.kicad.info/t/decoupling-capacitor-via-placement/25132/19
I have also posted there my example of 2 layer PCB designed with whole bottom used as GND zone:
https://forum.kicad.info/t/approaching-pcb-track-routing-for-a-newbie/36302/8
Offline Faranight
  • Country: si
« Reply #2 on: October 09, 2024, 03:41:30 pm »
At a quick glance, my comments are:
- The first thing I noticed is lack of a filled GND plane. That's the first thing you should do, typically on the bottom plane.
- Power traces should typically be a bit thicker than the signal traces, and they should route power in a star-like formation. They should not snake around.
- Similarly, some signal traces look like they are routed over a way too long path than they should be, and they are switching the layers too often. Perhaps reroute them in a similar manner - a star-like formation instead of a snake-like pattern. The board looks like a labyrinth.
- U1 could probably use a 100nF decoupling cap close to its Vcc and GND pins.
Happy PCB'ing!
Fara-day? Fara-night.
Offline pcprogrammer
« Reply #3 on: October 09, 2024, 03:55:20 pm »
Another thing is to let go of the forced 45 degree steps in the places where the board is angled. Specifically the track on the red layer near JP4 and JP3.
Another thing near JP4 is the two vias very close to each other that can be reduced to a single via with just one connection to JP4.
Also look at the component markings on the silkscreen. Try not to overlap them and get a better readability and indication which belongs to which component. Maybe make them a bit smaller.
As the others mentioned a proper ground plane reduces on problems, and may even clear up space on the top layer for a better signal layout.
If possible pin swapping can also help. With general IO pins on a MCU or FPGA it is at times possible to just swap some IO to make the routing easier and use the new assignments in the software. Back in the TTL chip days it was called gate swapping within devices with multiple gates in them, like 4 AND gates or 6 inverters.
Online Bud
« Reply #4 on: October 09, 2024, 05:04:25 pm »
Where is mounting holes? How the board is intended to be mounted?
Offline tooki
« Reply #5 on: October 09, 2024, 06:25:15 pm »
In addition to mounting holes, you probably want to leave more space between the edge of the board and any copper.
Offline Refrigerator
  • Country: lt
« Reply #6 on: October 10, 2024, 10:19:23 am »
Now that's what you call a proper rats nest.  ;D
*GND plane is missing.
*In terms of I2C, bad design will only limit your baud rate.
*Wider tracks for power stuff.
*Feels like you have too many unnecessary layer changes.
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
