Thanks guys, I'll try and digest your replies, here's hopefully a readable full circuit
Still not clear what C110 does, assuming the circuit diagram is accurate. However whatever effect it does produce will be quite minor as the low amplifier load resistance will be dominant with the higher value resistors R117 and R118 connected to C110 isolating its affects from the output.
My best guess is that connection of R117 and R118 slightly modifies the DC bias position of the upper and lower and lower halves of the push-pull output stage to overcome some residual distortion problems. Since the value of C110 is quite large it comes into play for frequencies above 1Hz further modifying the load on the output stage to perhaps control distortion problems. With the low frequency where C110 has an effect it suggests that there may have been thermally induced distortion problems in the output stage and this was an attempt to alleviate those problems.
Of course all of the above is just speculation. Probably the only way you will find out for sure is to ask the original designer.
