I have not seen the code "1J4" before, but I assume it means 1.4 ohms, 5% tolerance since "J" as a suffix in the more normal "1R4J" denotes 5% tolerance (K=10%, F=1% are other common suffices).
Probably done to save one precious space in the label, since sometimes wiring diagrams get crowded with complicated part values. Incidentally, 1.2, 1.3, and 1.5 are the common values for 5% resistors, but not 1.4.
