Author Topic: what does the apostrophe symbol mean in this exponential converter equation?  (Read 5148 times)
Offline dentakuTopic starter
I just started reading a document on "log and exponential (antilog) circuits" from this document http://electronotes.netfirms.com/s019.pdf
It's make more sense to me now than I did the first time I stumbled onto it quite a while ago but I have a question about mathematical symbols.
In the first equation Ic = I'eqVBE/kBT
What does the apostrophe symbol " ' " mean?
I can plug in values as well as anyone else but when the equation contains symbols I don't understand it's not terribly useful.
Offline c4757p
  • adieu
It tells you!
I' is the "reverse saturation current" ~ 10-12 amps
It tells you!
Doh!
I read that but didn't notice it included the '.
Offline T3sl4co1l
    • Seven Transistor Labs
Usually denoted as "Is"..
Seven Transistor Labs, LLC
Offline KJDS
    • my website holding page
I was going to suggest that you hadn't cleaned your screen properly
Offline T3sl4co1l
I'd post some suggestions, but on second thought I probably shouldn't go searching for "how to clean your screen" links... ;D ;D
Offline Mechatrommer
  • Country: my
  • reassessing directives...
using aposthrophe just to distiguish different variables of related or similar thing (just like OP to differentiate 2 type of current Ic and I') is not an elegant way. "Ic" symbol is ok but I' that stands for "Is" is not good, "Is" symbol is more elegant. as "'" usually means "inverse" or "image" of the variable. such as if Is is saturation current then Is' is its inverse or 1 / Is. next time pass the word to anybody who want to write something academic or to young kids in schools.
Offline ctz
This is a prime, not an apostrophe. It's really common in science, engineering and maths texts.
http://en.wikipedia.org/wiki/Prime_(symbol)#Use_in_mathematics.2C_statistics.2C_and_science
Nice.
That was rather educational.
