Author Topic: What is that component ?  (Read 299 times)
Offline LavalTopic starter
« on: April 15, 2026, 12:09:58 am »
This is a standby power supply that was in a UPS. It works perfectly fine but I'm curious as to what the component shown on the picture is. I'm talking about the aluminium block just beside the DC-DC switching IC.
This is only connected to the ground plane and to the solder lines on the other side of the board. Its designation is HS5 which would suggest a heat sink but there is no component mounted on it. If it is a heat sink, is it there to dissipate heat from that area of PCB ?
I would rather have questions that can't be answered than answers that can't be questioned.
- Richard Feynman
Offline coromonadalix
Re: What is that component ?
« Reply #1 on: April 15, 2026, 12:23:59 am »
i think they added thermal mass dissipation with this part,  to help the smps  ic  to dissipate
Online Psi
« Reply #2 on: April 15, 2026, 12:41:16 am »
Probably cheaper than solving the heat issue with thicker copper PCB tracks.
Bit odd that its a solid block, be better to add some fins to it. But i guess that is an extra step that adds cost and was not required to get the thermal performance.
It may have been more about lowering a concentration of heat to keep the electrolytic caps at a safer temp. Rather than dissipating heat from anything in particular. Electrolytic cap lifespan falls like a rock at higher temps.
« Last Edit: April 15, 2026, 12:45:42 am by Psi »
