actually i looked up aliexpress and ebay, found the identical one as i have, ordered at aliexpress - listing said last item in stock, a month later empty bag comes...
just two days ago i got dmm ordered on ebay, and of course it is not the same one although looks almost identical
the idea was to first test both energizer batteries in new unit (as i've previously seen some batteries are just not good for this device) and then compare measurements on PCBs
the thing i received works on AAA batteries, PCB is different without external IC components, in general i don't like it: screen tries to follow up with fancy models by adding unnecessary AC,DC,ohm, buzzer etc symbols ending up in reducing actual digit thickness, but worse than that is viewing angle is practically useless
it also auto shuts down every 10 minutes, even if it is in use during that time. and makes a lot of annoying beeping, before auto shutdown and while changing range. when i only want it to beep in continuity mode. plastic casing looks of worse quality than earlier revision as well as sticker on top of it with all the range indicators (i did not even realize this is a sticker, because it looked way more realistic on earlier revision, until i noticed this on new unit). the item is the same as on attached photo, just without any logo on top, only DT9208A printed (PCB is XT9208V2)
definitely need to repair my old unit, no way i can use this and be happy with it
