Author Topic: What to do with fifty 15kR - 50W power resistors?  (Read 2144 times)
Offline japasetelagoasTopic starter
  • Country: br
  • Just an ordinary electronics hobbyist.
« on: September 25, 2017, 04:48:09 pm »
Hey everyone,
I've seen a carbox with maybe 50 Dale power resistor in the junkyard, is there anything useful that could be done with these resistors?
Maybe a dummy load or something else?
15kR - 50W - 1%
Thanks
The endless river...
Offline kalel
Re: What to do with fifty 15kR - 50W power resistors?
« Reply #1 on: September 25, 2017, 05:27:37 pm »
I guess that to reach the power rating a high voltage would be needed. Of course, then a heatsink is needed also. I'm not sure how many W you could dissipate without adding anything.
Offline edavid
« Reply #2 on: September 25, 2017, 05:38:17 pm »
Here's the datasheet: https://www.vishay.com/docs/50013/rh.pdf
The unmounted power rating is 12W @ 25C.
Offline ElektroQuark
    • ElektroQuark
« Reply #3 on: September 25, 2017, 05:41:39 pm »
A 300R 2500W resistor?
Offline Benta
« Reply #4 on: September 25, 2017, 05:44:51 pm »
Dunno what you mean by "15kR". Those are 1 ohm resistors and can come in extremely useful as dummy loads. Especially as they are 1% tolerance. Go for it.
    • ElektroQuark
« Reply #5 on: September 25, 2017, 05:46:18 pm »
15kR -> 15K Ohm
The image must be a generic one.
  • Country: br
« Reply #6 on: September 25, 2017, 08:08:46 pm »
15kR -> 15K Ohm
Exactly.
Offline innkeeper
« Reply #7 on: September 27, 2017, 01:20:29 am »
i have a crap load of precision resistors and caps. maybe we can do some trading if it helps your parts inventory, if your reasonable distance from me and it makes economic sense.
Hobbyist and a retired engineer and possibly a test equipment addict, though, searching for the equipment to test for that.
Offline tpowell1830
  • Peacefully retired from industry, active in life
« Reply #8 on: September 27, 2017, 01:26:17 am »
Hey everyone,
15kR - 50W - 1%
Thanks
Better grab all you can, those are not cheap. Someday you will find a use for some of them. Give some away on the forum, or sell them.
PEACE===>T
Offline bjcuizon
  • RF and Analog Electronics Enthusiast
« Reply #9 on: September 27, 2017, 03:03:53 am »
Make a 50 ohm HF dummy load if you got more than 50 resistors. :D
Don't mess with an Electronics Engineer, it Megahertz!
Online Ian.M
« Reply #10 on: September 27, 2017, 03:27:42 am »
3.5W dissipation at 230V means they'd be useful as an anti-condensation heater for small mains powered enclosures.
Offline innkeeper
« Reply #11 on: September 27, 2017, 04:05:01 am »
heaters for a 3d printer heated bed?
Fishing weights?
slingshot ammo?
throw them under your tire for extra traction when stuck in the winter time.
non environmentally friendly replacement for water skipping stones.
