Hello,
Supposing there is a LED streetlight which flickers as in the attached. (that’s actually the light output, not a voltage). As you can see, the light output actually goes to zero every 10ms.
Will this cause a problem for CCTV cameras at night ?
Will this cause a problem for Number plate recognition cameras at night?
Will this cause a problem for police dash-cams at night?
Supposing if the exposure time is 1ms, and it takes 1 picture per second, then surely in theory the images could all be black?
