Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Beginners
will this circuit work?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: will this circuit work? (Read 1707 times)
Sounduser
Contributor
on:
June 16, 2015, 12:51:13 pm »
I've got an rgb party light that flashes to music.
It's basically LEDs that are switched on the low side by a microcontroller.
I want to connect it to some rgb led strip.
Will this circuit work?
Thanks.
Logged
PSR B1257
Frequent Contributor
Country:
Re: will this circuit work?
Reply #1 on:
June 16, 2015, 03:35:25 pm »
If the GND-terminals are connected, yes.
The P-channel MOSFET can be replaced by a small signal BJT.
Logged
In theory, there is no difference between theory and practice. But, in practice, there is.
Sounduser
Contributor
Reply #2 on:
June 16, 2015, 08:14:33 pm »
Okay. Just a straight swap with a pnp transistor. No extra resistors?
Logged
GoneTomorrow
Regular Contributor
Country:
Reply #3 on:
June 17, 2015, 10:44:29 am »
Yep, you already have your base resistor, just emitter to 12v and collector to your MOSFET gate.
Logged
Sounduser
Contributor
Reply #4 on:
June 20, 2015, 11:31:23 am »
What value resistor would you use?
Thanks guys.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Beginners
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
