I'm adapting some headphones for use with a portable audio device, and have experienced some success: sound comes out and no smoke... but the sound is very faint. I think the reason is that portable devices assume efficient, low impedance earphones in the 15 ohm impedance range, while the ones I'm trying to drive are somewhere in the 150-300 ohm range.
The solution I'm thinking of trying is to wind a couple (one per channel) of toroidal transformers with a suitable turns ratio. I understand the n^2 impedance thing, and would choose a toroid of a size I can hand wind without use of a microscope, and since we're talking tens of milliwatts, I figure the wire wrap wire I have on hand should do okay.
But I have absolutely no idea what composition I should look for for use in the audio range. I'm guessing ferrites I've salvaged from PSU's were designed for much higher frequencies.
Can anyone offer useful advice regarding size/composition/sources of toroidal cores I should look to for this application?
Thanks!
