Author Topic: [Solved] Wooden BT speaker display, how it's done ?  (Read 2298 times)
Offline dheadTopic starter
« Last Edit: December 20, 2014, 07:04:25 pm by dhead »
Online Monkeh
Re: Wooden BT speaker display, how it's done ?
« Reply #1 on: December 20, 2014, 05:21:08 pm »
The 'wood' will have been routed to a very thin layer, and some bright LEDs put behind it.
Realistically it's probably just the melamine veneer over some entirely routed out chipboard.
« Last Edit: December 20, 2014, 05:22:56 pm by Monkeh »
« Reply #2 on: December 20, 2014, 07:03:51 pm »
Oh, that's simple while it's still a nice solution.
I'll definitely going to this solution in project box.
Thanks @Monkeh
Re: [Solved] Wooden BT speaker display, how it's done ?
« Reply #3 on: December 21, 2014, 08:06:07 am »
Looks like a low density wood ( soft fast growing plantation like pine, balsa or such light wood) block that is cut using a CNC or a milling machine to leave a 1mm or so recess for the LED displays on it. Then the buttons are most likely done using a thin ( 2mm or less ) recess and having capacitive switches on a PCB there, or by making it 1mm and mounting the switches in a recess that allow just pressing on the thin wood to operate them.
