Author Topic: worth buying a soldering station?  (Read 1793 times)
Offline electromateriaTopic starter
« on: October 16, 2021, 03:18:29 am »
what u guys think? I need something reliable for years to come....
some of the soldering stations I'm looking at are over $120. should I get one or only buy a $40 soldering iron? I'd prefer the cheap option but only if it works well and is reliable.
Offline bob91343
Re: worth buying a soldering station?
« Reply #1 on: October 16, 2021, 04:07:25 am »
Every soldering iron is different.  No one will satisfy all soldering needs, so you need to decide what capability is appropriate for your situation.
I currently have at least 10 soldering tools.  Propane torch down to ultra tiny USB powered unit, and even a hot air device and some soldering guns (ouch).  The one I use most is the Weller TCP I think it is.  Runs maybe 40 Watts and is temperature controlled and has its own little station.
Offline radiolistener
  • Country: ua
« Reply #2 on: October 16, 2021, 05:02:44 am »
You're needs soldering iron (with temperature control) and hot gun (the same with temperature control). Hot gun is needed for desoldering.
Probably it's better to buy inductive soldering iron, it better keeps temperature. But I still using old Goot RX-711.
Regarding the hot gun, it cost about 30 USD on aliexperss, for example:
https://www.aliexpress.com/item/32818260663.html
These hot guns are based on unknown Chinese controller, so if it fails you cannot repair it, but most of all if it fails it will be triac and you can replace it, it uses BTA12. And it is not so expensive.
« Last Edit: October 16, 2021, 05:31:43 am by radiolistener »
Offline Capernicus
« Reply #3 on: October 16, 2021, 05:07:13 am »
inductive would be safer,  less shock risk.  same with heating water.
Offline ebastler
« Reply #4 on: October 16, 2021, 05:22:37 am »
You are recommending an inductive soldering station to someone who is reluctant to spend $120 (Canadian dollars presumably)? Which model did you have in mind?
  • Country: ua
« Reply #5 on: October 16, 2021, 05:41:35 am »
For example $100: https://www.aliexpress.com/item/33031331141.html
But I didin't tried it, so I cannot say anything :)
Offline ledtester
« Reply #6 on: October 16, 2021, 06:24:50 am »
You can do a lot with a cheap soldering iron. Just have a look at what some of the big electronics youtubers use:
bigclivedotcom:
Soldering basics and choosing a cheap soldering iron
-- https://youtu.be/aIab66EgfHM
GreatScott!:
Soldering iron shots:
- https://youtu.be/j1V2I-otdzk?t=83
- https://youtu.be/j1V2I-otdzk?t=603
Electroboom:
- https://youtu.be/jW3_txSfIAQ?t=9m24s
bitluni:
- https://youtu.be/wvBFtz7Ioio?t=76
w2aew:
- https://youtu.be/TrdlKlkLdVQ?t=90
Granted, there will be some tasks that will be more difficult without a temp controlled iron, but a lot of people -- including a lot of professionals -- have gotten by with a basic iron.
Offline xavier60
« Reply #7 on: October 16, 2021, 09:02:55 am »
For anyone who can afford a bit extra, the FX888D is well priced at the moment. I bough one a few years ago for my main work bench, now I'm replacing my old 936 clones with new FX888D's.
FYI, Preset mode isn't enabled by default, so be prepared for some frustration until you realize that the instruction leaflet makes no mention of it and a search needs to be done.
https://www.oritech.com.au/hakko-fx888d-soldering-station.html
https://www.mektronics.com.au/hakko-fx-888d-digital-soldering-station-genuine-incl-free-roll-of-solder-mc334.html
« Last Edit: October 16, 2021, 09:07:22 am by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline daveho
« Reply #8 on: October 16, 2021, 01:31:29 pm »
I bought a Yihua 937D+ a few years ago for about $30, and I've gotten a ton of use out of it. Personally, I prefer it over the Hakko FX888D. It's a pretty decent soldering station.
Online tooki
« Reply #9 on: October 16, 2021, 01:54:59 pm »
Shock risk? Standard soldering stations use 24V to power the iron. That poses zero shock hazard.
Offline Canis Dirus Leidy
  • Country: ru
« Reply #10 on: October 16, 2021, 02:38:49 pm »
These “I wanna be Quick” have one pitfall (copied, IIRC from the original Quick stations): you can't change soldering tip temperature on the fly, only in special (and protected with "password") mode, which can be entered only immediately after turning on the power.
P.S. Plus, you will need external thermometer for calibration. My BK2000 has 50 degrees of difference between display reading and tip's temperature. And, according to the operations manual, such calibration is required after each change of soldering tip.
« Reply #11 on: October 16, 2021, 05:14:05 pm »
I was thinking of getting a desoldering bath, is the heat gun a better option?
Thanks for all the suggestions guys, much appreciated!
  • Country: ua
« Reply #12 on: October 16, 2021, 07:37:20 pm »
electromateria
hot gun is must have for SMD components. You can also use it for soldering, but it requires special flux with solder mixed in. I'm using hot gun for desoldering and sometime to fix soldering made with soldering iron.
With hot gun you're just put hot air for 5-10 sec on SMD component and then easily remove it with tweezers, very easy and simple :) But it needs to be careful to avoid overheating.
After that you can reuse that SMD component in a new device.
I don't have desoldering bath and never used it, so I can't say something about it. I just don't see the reason to buy it for my needs.
« Last Edit: October 16, 2021, 07:44:42 pm by radiolistener »
The following users thanked this post: electromateria
Online BrokenYugo
« Reply #13 on: October 16, 2021, 07:51:37 pm »
The "T12" type stations currently provide the best bang for buck, as low as $40-$50 USD all in direct from China. Any station is way better than an unregulated iron, nicer cable (typically silicone even on the cheap ones), tip selection, variable temperature, and more power for the size.
For example: https://www.aliexpress.com/item/32803295956.html
Offline Ground_Loop
« Reply #14 on: October 17, 2021, 02:27:56 am »
For me, a significant part of making really nice things is using really nice tools to make them. Wait, save up, and get a nice tool. I've used every imaginable kind of soldering tool including an iron used for stained glass controlled by a variac.  I later invested significantly in professional grade soldering equipment and never regretted it.
There's no point getting old if you don't have stories.
Offline joeqsmith
« Reply #15 on: October 17, 2021, 03:25:16 am »
It all depends what you you need to do.   I've demonstrated soldering with two home made electric irons and one where I used a 100 year old blow torch to heat a custom made iron to do some SMT work.  :-DD   There's nothing wrong with using a pencil.  I still have a few of them.
The best iron made will not turn you into a solder prodigy.   Likewise, develop some skills and you may find you can solder with most anything.
« Last Edit: October 17, 2021, 03:38:58 pm by joeqsmith »
Offline all_repair
« Reply #16 on: October 17, 2021, 04:05:32 am »
Get a T12 first.  You may need an inductive one for higher wattage in future, buy that when the needs arise as you can a get a better and cheaper one then. There are more portable and battery powered T12  coming out.  You can standardise on T12 tips for both the table top and portable irons. For having widest varieties of tip and yet keeping minimum spare, and mostly to keep and to improve your soldering "fu" by sticking to the same type of tip.  Original tips are better, you can get best value for lightly used original tips from Japan.
I have an inductive soldering station, never use for my work yet.  It is Heavier, so my skill haven't built up, may not have chance to build up.  Don't think I can use that to do SMT soldering.  I still prefer using 936 tip to do SMT, now slowly able to use T12 to handle SMT.
There are ready made adapters to use your T12 or 936 iron to fit a blade that you can use to cut plastics, or remove adhesive,  or fit it with silicone heating pad and use it to reheat the LCD ribbon.   Many possibilities, you can do your adapters, it is easier to buy off the shelve.
Offline james_s
« Reply #17 on: October 17, 2021, 04:18:08 am »
What do you want to do with it? That's going to have a big impact on what makes the most sense to buy. I bought my soldering station over 20 years ago and at the time I paid more than $120 for it used, the cheap Chinese stations weren't really a thing yet. I've used it very heavily for over 20 years so the cost amortized over that period is negligible. I've never regretted spending too much on tools. I have regretted trying to save money by getting cheap tools a number of times.
