I recently bought a electric bike charger on ebay that was for made for charging 48v Lithium packs at ~3A. I however need it to charge my 36v Lithium pack, so I am in the process of altering the various voltage dividers that would essentially lower the voltage to the appropriate levels. So far everything is working fine, I'm getting a stable output voltage and the battery charging controller is doing what it should. The only problem is that it is making an annoying audible whine is made, and has always been there even before I first opened it up. I would like to remove said whine, but it is originating near a part of the circuit with several possible culprits are positioned too close to each other to determine which is making it.
So what I would like help with is this. How would you find which of 4-8 components is making the whine, in about a square inch/25mm area?
