Newbie here. I've been using my XGecu T48 Programmer to read and program EPROM's for over a year now without any issues. Last night, I tried to read a AT27256 EPROM and I received "Check ID Error! Checked ID is:0x 8F 04". I tried other model EPROM's and received the same error. I updated the software and firmware last night. That didn't help. Then I sprayed DeoxIT into the disconnected programmer, and left it upside to dry for the night.
This morning, I tried again and got the same error on several model chips. In the Xgpro V12.66 software I'm using, if I uncheck the "Check ID" box, I can read the chips just fine. I never had to do this before. This setting is on by default every time you change the chip model in the software.
Is there a connector in the T48 that is used to perform the Check ID function that might be faulty? Or is it something else? I'm tempted to just buy another one from Amazon so that I can see if the new one does it too.
Any help is appreciated!
Joe
