Hello all,
Thank you all very much for your replies and advice - greatly appreciated and a useful learning experience.
Here is what I found carrying out the practical tests suggested:
Connecting in series the VC99 DMM, a 1k resistor and the 3V Zener and applying exactly 1.1V to the circuit, I see 10.1uA on the meter. When I drop the voltage to 1V, I read 5.4uA.
Leaving everything in place, setting the VC99 to 60mA range and applying 13V to the circuit, I see 10.14mA on the meter. At 12.84V I am able to achieve exactly 10mA. Measuring the voltage across the Zener, it reads 2.84V.
With 100 Ohm resistor replacing the 1k resistor and an input voltage of 6V, I get 27.6mA on the meter. I measured 2.74V across the resistor.
So, given the test results above, I presume it is safe to conclude the UZ-3.0B I have is in fact functioning normally? Or, do you think I should I carry out further tests with different resistor values and currents to create a graph of the performance curve to be more sure of this?
The advice you see on Youtube by various video publishers is very binary when it comes to testing Zener diodes with a DMM, i.e. OL=working, any voltage observed = faulty. I think the publishers of such videos really ought to provide at least a caveat for low voltage Zeners; otherwise, it can be very misleading.
Thanks!
