Author Topic: 6.5W in standby!  (Read 25481 times)
Online tom66Topic starter
6.5W in standby!
« on: April 18, 2011, 04:52:23 pm »
Ouch! When I saw that I was really surprised. What could be eating so much power? Is the scope getting any standby power for features like wake on LAN? 6.5W per hour works out to 1kW per 153.8 hours, if you put that into a year of standby (ignoring the time it is on, of course, where it uses ~60W), it works out to 57kWh, or about £7.41 per year where I live... not much, but not something you can ignore.
I like my HP 54501A, because it has a true power switch. The switch is actually embedded into the power socket and has a long plastic lever, like the one in the Agilent, going to the front for the power switch, and I know it's a real switch because there are only three wires exiting the socket (live, neutral, earth.) :) Why not just make it a tactile switch and make it wake up quicker? If it already draws 6.5W in standby I can't think it would take too much to put the processor and the rest of the board in a low power sleep mode so it can wake up in a few seconds compared to the 30 seconds for Win CE to boot up...
Offline Zero999
  • 0999
Re: 6.5W in standby!
« Reply #1 on: April 18, 2011, 05:04:13 pm »
Unless it has features such as a timer and wakeup, it's probably laziness - it's easier not to route cables with insulation thick enough for mains round the 'scope case to the front panel.
Offline Rufus
Re: 6.5W in standby! (Agilent X2/3000 scopes)
« Reply #2 on: April 18, 2011, 06:14:27 pm »
It uses a 13v OEM version of this PSU module .
http://www.lineagepower.com/oem/pdf/cch125.pdf
The scope power switch despite being mounted right next to the mains input filter controls the 'REMOTE' input of the PSU. All the 'standby' power dissipation is down to the PSU module.
I wouldn't take 6.5W as gospel, it doesn't feel like quite that much to me. Hard to measure low standby power accurately. Anyone have a scheme for that, preferably one that doesn't require a scope - lol.
« Reply #3 on: April 18, 2011, 07:02:15 pm »
Hmm interesting, perhaps that explains all the secondary power supply stuff on the mains input board. Seeing all those TO-220's gave me the idea that it had more than just a 12V or 13V rail (was expecting at least 5V and probably a negative rail too.)
Offline sacherjj
« Reply #4 on: April 18, 2011, 07:03:41 pm »
An easy way to measure this kind of stuff is with a Kill-A-Watt power meter.  It can measure an AC device for power over time.
Online EEVblog
« Reply #5 on: April 18, 2011, 09:08:46 pm »
The Gossen meter is perfectly capable of uW measurements. Believe it.
Dave.
Offline Rufus
« Reply #6 on: April 18, 2011, 11:21:43 pm »
You didn't say what you measured it with, and now only that it is a Gossen, so I assume a Metrahit energy.
I looked at the data sheet for that and couldn't figure out what it was able to measure taking frequency and harmonic content into account, although I expect it would probably read low for something it couldn't properly handle.
Anyhow, I stuck 90, 100, and 110v dc into the scope and measured 5.16, 5.31, and 5.33 watts so yes now I believe 5 or 6 watts rather than the 2 or 3 I guessed at from how warm it got.
Online EEVblog
« Reply #7 on: April 19, 2011, 02:16:43 am »
It's all in my latest video.
Yes, I used the Metrahit Energy.
I have another Silicon Chip power meter kit that also goes down to 0.01W resolution with reasonably accuracy.
Beware some of the cheap Kill-A-Watt type devices, they can't measure low powers accurately.
Dave.
Offline alexwhittemore
« Reply #8 on: April 19, 2011, 02:27:11 am »
This made me want a Metrahit Energy, so for giggles I looked it up on Conrad's website. HOLY CRAP, 970 EUR?! DAMN!
Offline Rufus
« Reply #9 on: April 19, 2011, 03:04:10 am »
I hadn't seen the video - wondered why the OP started a new thread - lol.
There is a service guide you can download which tells you how to check the mains input, the power switch, and the voltages coming off the filter board.
There are a lot of similar 3x5" power 'bricks' available. Couldn't find one that specified disabled or no-load power consumption.
Offline AdShea
« Reply #10 on: April 19, 2011, 03:32:42 am »
Though it would void your warranty it doesn't look like it would be too hard to swap out that switch to open the mains instead of running that remote pin.  Thankfully Agilent already gave you a nice post to the front panel for the button.
Online EEVblog
« Reply #11 on: April 19, 2011, 03:56:15 am »
Err, yeah, Gossen meters aren't cheap at the best of times, but quite simply the best meter I've ever owned.
Try their 6.5 digit multimeter.
Dave.
« Last Edit: April 19, 2011, 07:43:09 am by EEVblog »
Online EEVblog
« Reply #12 on: April 19, 2011, 03:58:03 am »
Yeah, some people watch the Youtube channel were the video gets posted first, sometimes 24hours or so before it makes it to the main eevblog.com site and feed.
Where is this service guide?
Dave.
Offline jahonen
« Reply #13 on: April 19, 2011, 07:20:42 am »
I can confirm that MetraHit Energy measures even idle consumption of mobile phone charger with ease, likewise it handles non-linear loads just fine. Anyway, measuring non-linear loads should not be rocket science nowadays anyway.
Regards,
Janne
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #14 on: April 19, 2011, 08:34:20 am »
I really don't see what the fuss is about.
Their solution is going to be more reliable as you don't have a switch handing inrush currents or switch-off arcs, and there is no inrush stress on the PSU.
Mains-rated fully approved double pole mains switches are pretty large, and would have been a struggle to fit in the space on that board while maintaining clearances to the shield.
There will never be enough of these scopes in the world for the wasted energy to be an issue, and the cost to individual owners is negligible compared to other stuff that people leave on all the time.
My only minor concern is the physical robustness of that switch, but it's not  going to be a big deal to find a replacement if it eventually falls apart - finding exact replacements for a mains switch could be a lot harder.
Day Job: Mostly LEDs
Offline hacklordsniper
  • Country: hr
  • Don't turn it on, take it apart!
    • HackLordSniper
« Reply #15 on: April 19, 2011, 09:29:30 am »
Dave since you hace contact with Agilent, did you try to ask them about their follow up?
Oh, the joy of sending various electronics to silicon heaven
Offline Fryguy
« Reply #16 on: April 19, 2011, 10:01:02 am »
Dave mentioned in the video that this is not the 70's - Dave , you're exactly right about that !
My vintage 70's Tek 7603 Scope which i still use has got A REAL MAINS POWER SWITCH !  ;D ;D ;D
You push it and it draws zero .
My 35 year old Tek uses a lot more power than a brand new Agilent and the switch still works perfectly after all these years - it can't be that hard to find a suitable power switch for a small SPSU .
And when i see the price you have to pay for these Agilent scopes , a real mains power switch should be well inside the budget . . .
Born error amplifier  >.<
Offline comox
« Reply #17 on: April 19, 2011, 11:17:00 am »
An expansion on my post on your blog....
Nice one again!  I am obsessed about standby power consumption and have a couple of Yokogawa WT210 power meters which I use to analyze appliances and such, which are very accurate down to the 5ma range.  I have a Tektronix MSO4032 which has a big mechanical pushbutton switch on the front which I ASSUMED isolated the power supply circuit from the mains when off.  After viewing your blog I hooked the MSO4032 up to the WT210 and here are my observations:
MSO4032 on: 238V (UK Mains), .361A, 77.54W   (Mode RMS)
MSO4032 standby: 241.92V (UK Mains), 3.57ma, 0.0007W (Mode RMS)
Pics attached.
Sorry Dave, but I am not going to take my scope apart and look at the PSU circuitry, however I imagine that there may be some line filtering circuitry of such (e.g. MOVs) which result in some sort of measurable leakage current.   The Yokogawa WT210 is an approved meter for Energy Star compliance and can be trusted to measure standby power consumption, and cost about £3000 each.  (Amazingly the second unit was purchased on eBay for about £600.)
I agree that 6W standby is out of order in today's times.  We are all fully aware of the environmental impact of energy consumption, and companies should incorporate features such as mains isolation into their product designs.  Unlike a PC, TV or a set-op box, there is no reason to have a scope on standby.
I have gone as far as measuring the standby power consumption of supposed "green gadgets", such as a power strip that would shut off devices (e.g. DVD, set-top box) when your TV is turned off (i.e. UK Dragon's Den gadget from a few years back), and was saddened to discover that the cheap PSU that powered it drew 1W in standby, which was more than my TV consumed in standby!  Oh well..........
Comox
« Reply #18 on: April 19, 2011, 11:26:56 am »
This is the sort of politically correct greenery that really annoys me. Standby consumption is only an issue in products like TVs, phone chargers  and set-tops because there are so many of them. It is a totally insignificant issue for niche products, as there just aren't enough of them to ever have any significance.
Long-term, the effect of product standards in high-volume markets will trickle down in the form of improved controller chips etc., and there will probably come a point where all off-the-shelf PSUs will have good standby and no-load performance, but there's no real justification to spend more money on it now.
And don't forget that a significant proportion of standby and active wasted power will be partly offset in any environment that is normally heated.
Online EEVblog
« Reply #19 on: April 19, 2011, 11:37:58 am »
That's a nice bit of kit!
Thanks for the measurements.
Dave.
Online EEVblog
« Reply #20 on: April 19, 2011, 11:44:57 am »
The actual numbers and whether or not it matters is pretty moot.
The point is that it's just generally poor engineering, and doesn't help drive the industry in the right direction IMO.
If Agilent insisted on a low standby supply, then they help create need for better low standby supplies, and at the same time lower the demand for high standby supplies, thus helping drive the industry forward.
As designers we all have a part to play in this, it's just poor form for such a reputable company (or any company for that matter) to rely on others to do this and think it's their problem and it will "eventually trickle down".
Dave.
Offline comox
« Reply #21 on: April 19, 2011, 01:31:43 pm »
Okay, lets look at it in terms of beer.   6W standby for 1 year @ 13p/kWH = 2 pints of beer!
Now are you convinced that standby power consumption is a problem?
Offline Rufus
« Reply #22 on: April 19, 2011, 01:41:42 pm »
http://www.google.com/search?q=Service+Guide+for+2000_3000+X-Series+Oscilloscopes
Will find it. Agilent site links are a bit too horrid to post.
If 1% of a household's power consumption is 'wasted' standby power the (in)significance is 1%. There being one household or 100 million the (in)significance is still 1%. The only bearing on cost benefit analysis is how many units development costs can be spread over.
Agilent screwed up. The problem is the mains switch. All reliability arguments about keeping the PSU warm or inrush currents are invalid because any problems caused by a real mains switch are also caused by turning the scope on and off at the wall socket.
Offline tnt
« Reply #23 on: April 19, 2011, 02:21:45 pm »
IMHO:
* Should agilent have put a proper mains switch: Hell yeah, they should know better
* Will I resell my scope or not recommend it or loose sleep over it: Hell no ...
« Reply #24 on: April 19, 2011, 02:40:00 pm »
It may have 1% significance to that household, but negligible in global terms, and also negligible in terms of affordability to any household that owns a scope.
Agilent screwed up.
That implies an unintentional error. I doubt very much this decision was unintentional - more likely a business decision based on cost/benefit and/or availability of suitable PSUs. Every product is a compromise between cost and performance. This is simply not an important performance issue for a product like this.
Except that it gets turned on at the switch a lot more often than at the wall. The issue isn't so much reliability of the PSU, but the switch under inrush conditions.
My bet is they just didn't have space for a suitably robust mains switch (including track creepage distances to route it on the PCB and clearance to shields). Maybe the extra EMC filter on the power board was a late addition which used up space originally intended for a switch.
It wouldn't surprise me if it's actually quite hard to find a PSU like this with very low standby draw- last time I looked it was hard enough to find one with remote on/off - the one linked earlier doesn't even spec it at all. Low-energy directives are increasing the availability of more efficient PSUs, and a look at websites of people like Power Integrations will leave you in no doubt that efficiency and standby draw are headline features of new PSU semiconductors. It takes quite a while for these to percolate down to the market, and PSUs have high approvals costs which means they don't want to change designs if they can avoid it.
