Author Topic: Dave's power supply mods.  (Read 52116 times)
Offline markus_b
Re: Dave's power supply mods.
« Reply #125 on: March 14, 2012, 10:33:17 pm »
I agree, it'd be nice to figure out a way to either plug a Bluetooth or Ethernet module there.
The Bluetooth module is easy, you can use the Arduino-compatible serial connector to connect  it. A Bluetooth module needs Gnd, 3.3V, RX and TX. These are all there.
Markus
A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible.
Offline McMonster
    • McMonster's blog
« Reply #126 on: March 15, 2012, 12:28:08 am »
My thought was "something that fits there without some hacking or bodgy wires". The socket would be most likely placed so it aligns to the hole in the case and there's probably no direct replacement BT module that would match the socket pins. So we're either mount the module somewhere else and do some wiring or design a custom daughter board that can be plugged nicely, fit's the space and is mounted securely for moving the whole unit. Not that someone would play american football with the PSU, but if it's portable then the construction must be prepared for thing you don't do with most of the bench equipment. Or at least it must be built like old school bench hardware, I'm pretty sure I can airdrop my Wavetek without a chute and it'll survive. :P
Offline sacherjj
« Reply #127 on: March 15, 2012, 01:15:56 am »
I'm betting there would be space to have an adapter board, with pins and headers.
