Author Topic: EEVblog #1144 - Padauk Programmer Reverse Engineering  (Read 400720 times)
Offline KaeTo
Re: EEVblog #1144 - Padauk Programmer Reverse Engineering
« Reply #1350 on: May 20, 2021, 04:54:58 pm »
Okay, thank you. I think that is the case. I use the uC at 8MHz
Offline js_12345678_55AA
  • Country: ht
« Reply #1351 on: May 25, 2021, 12:59:23 pm »
I added a new example "Noiseplug" to the easy-pdk-showcase-projects: https://github.com/free-pdk/easy-pdk-showcase-projects
* Noiseplug is a chiptune player for ATTiny9 created by "dojoe/shack" presented @evoke2012:
* Pouet: https://www.pouet.net/prod.php?which=59694
* Source: https://github.com/dojoe/noiseplug
Out of curiosity I wanted to see how well assembly code from ATtiny can be ported to PADAUK.
It turned out, very well (unless you use any peripherals like UART or high speed clock (20MHz) from ATtiny it is possible to port assembly programs almost 1:1).
Just for fun I also added a tiny PFS154 emulator which loads an .IHX hex file, interprets the PDK14 instructions and sends the PWM output of TM2 to the host computer's sound device (your host computer needs to run at least @150MHz).
=> https://github.com/free-pdk/easy-pdk-showcase-projects/tree/master/noiseplug/emulation
JS
P.S. @gir:
I modified your bsv makefile to compile for pdk14 and changed 2 things in my emulator (512 instead of 256 syclocks, trigger TM16 int (0x04) instead of TM2 int) and it played the tune very well.
I think you can easily load noiseplug on your hardware (you only need to change the PWM output to use PA4)
Video of original ATTiny noiseplug (at demo party EVOKE 2012):
« Last Edit: May 27, 2021, 11:49:31 pm by js_12345678_55AA »
Easy PDK programmer and more: https://free-pdk.github.io
The following users thanked this post: gir
Offline gir
  • Country: at
« Reply #1352 on: May 29, 2021, 10:57:05 am »
P.S. @gir:
nice to see that my assembly was portable enough (i think i did use some magic numbers for bits-in-registers here and there...). and great job on your noiseplug port --  i'm definitely going to try that out!
  • Country: ht
« Reply #1353 on: June 04, 2021, 03:54:41 pm »
I stumbled over a comment on github (all in chinese) which is asking if we want to research the PFC886 together...
There is a repository with source here: https://github.com/stm8stm8stm8/pfc886/blob/main/pwm08b.C
Which according to the comment contains code for the "PFC886" IC which is also labeled "MF520".
After following the bread crumbs it turns out that PADAUK offers a special IC for brushless DC motors called the MF520:
http://www.padauk.com.tw/en/product/show.aspx?num=138&kind=44
In fact this seems to be an 8 core PADAUK with flash support  :) 8)
EDIT:After some more digging I found a video of the "making of" the above source code:
https://www.bilibili.com/video/av712877080/
The video contains some captures of the PFC886 datasheet (again all in chinese :-) )
EDIT2: In the video I was able to see that this IC has 512 byte of RAM  :o
Interesting....
« Last Edit: June 05, 2021, 07:40:47 pm by js_12345678_55AA »
The following users thanked this post: icraftcrafts
Offline suzhiming
  • Country: cn
« Last Edit: June 10, 2021, 09:20:16 am by suzhiming »
Offline suzhiming
  • Country: cn
« Reply #1355 on: June 10, 2021, 09:23:39 am »
/***************************************PFC886+MF520PWM**********************************************/
/***************************************QQ:774145445*************************************************/
/****************************************快手:共同学习STM8*******************************************/
/****************************************20210423****************************************************/
//                     _________   _________
//              PWM2L-|1 pa2    \_/   pa1 20|-PWM2H
//              PWM1L-|2 pa3          pa0 19|-PWM1H
//              pwm0L-|3 pa4          pa7 18|-pwm0H
//                    |4 pa5          pa6 17|-led_1
//         与gnd相连|-|5 nc            nc 16|-|与vdd相连
//                  |-|6 gnd          vdd 15|-|
//                k_1-|7 pb0          pb7 14|-led_2
//                k_2-|8 pb1          pb6 13|-led_3
//                k_3-|9 pb2          pb5 12|-led_4
//                k_4-|10_pb3_________pb4_11|-led_5
#include   "extern.h"
k_1         bit      pb.0;
k_2         bit      pb.1;
k_3         bit      pb.2;
k_4         bit      pb.3;
led_1      bit      pa.6;
led_2      bit      pb.7;
led_3      bit      pb.6;
led_4      bit      pb.5;
led_5      bit      pb.4;
void      zhengxianbo();      //正弦波
void      fuzhi();         //赋值
void      anjian();         //按键
void      yanshi();         //延时
word      a1,b1,c1;
word      yanshi_a1;
void   FPPA0 (void)
.ADJUST_IC   SYSCLK=IHRC/4      //   SYSCLK=IHRC/4
pmode      31;         ///8/8/8/8/8/8/8/8带宽共享
fppen   =   0xFF;      //8核全开有8个核心可以分时全部运行,可以分别干8件事8核真爽!
$      led_1      out,low;
$      k_1         in,pull;
$      k_2         in,pull;
/****************************************************************************************************/      //pwm配置
//f----------------0 f----------------0 f----------------0 f----------------0(word,int)
//f----------------0 f----------------0 f----------------0    //12位PWM0,1,2(左对齐)
// ↑上限(pwmcub)    ↑占空比(pwmdt)    |--死区(pwmdz)---|
//上限pwmcub=0xfff0,死区pwmdz=0xff,
//pwm0dtl(先写)pwm0dth,pwm1dtl(先写)pwm1dth,pwm2dtl(先写)pwm2dth,
//最大0xf010,        pwm_h=1+死区,    pwm_l=0,
//最小0x000,0x0010,  pwm_h=0,         pwm_l=1,
//PWM最大0x0fff-死区 =0xf000,
//PWM最小0x0000+2    =0x0020,
//pwm最大值取0xf000-0xff    =<0xef00高脉冲4us
//pwm最小值取0x0020+0xff    =>0x00ff高脉冲4us
a1=0xf010;fuzhi();yanshi();
//a1=0x0000;fuzhi();yanshi();
a1=0x0010;fuzhi();yanshi();
a1=0xf000;fuzhi();yanshi();
a1=0x0020;fuzhi();yanshi();*/
$      pwmgc      enable,updown,reset;
$      pwmgm      protection_enable,ihrc,/4;
//pwmgc      =0b1_0_1_1_0000;      //PWMG控制寄存器位7,停用启用位6,输出状态位5,中心排列模式位4,PWM计数器清零
//pwmgm      =0b0_0_1_0_10_10;      //PWMG分频寄存器位7,上臂反极性位6,下臂反极性位5,臂保护位4,臂保护模式位32,PWM时钟源位10,PWM分频
//pwmgm      =0b0_0_1_0_10_11;      //PWMG分频寄存器
pwmgc1      =0b1_11_0_01_10;      //PWMG控制寄存器1位7,互补发生器位65,三相电机位4,读零位32,PWM5.PWM+位10,PWM4.PWM-
pwmgc2      =0b01_10_01_10;      //PWMG控制寄存器2位76,PWM3.PWM+位54,PWM2.PWM-位32,PWM1.PWM+位10,PWM0.PWM-
pwmcubl      =0b1111_0000;      //pwm上限寄存器l
pwmcubh      =0b1111_1111;      //pwm上限寄存器h
//pwmdz      =0b1111_0000;      //死区寄存器
pwmdz      =0b1111_1111;      //死区寄存器//*注意死区占上臂时间需要扣除
//pwm0dtl      =0b1111_0000;      //pwm0占空比低位寄存器//先写低位
//pwm0dth      =0b1111_1111;      //pwm0占空比高位寄存器
//pwm1dtl      =0b0000_0000;      //pwm1占空比低位寄存器//先写低位
//pwm1dth      =0b1000_0000;      //pwm1占空比高位寄存器
//pwm2dtl      =0b1111_0000;      //pwm2占空比低位寄存器//先写低位
//pwm2dth      =0b0000_0000;      //pwm2占空比高位寄存器
while (1)
if(led_1){led_1=0;}   else{led_1=1;}
.delay   10000;
void   FPPA1 (void)
while(1)
void   FPPA2 (void)
yanshi_a1      =2000;
while(1)
anjian();
void   FPPA3 (void)
   goto   $;
void   FPPA4 (void)
   goto   $;
void   FPPA5 (void)
   goto   $;
void   FPPA6 (void)
   goto   $;
void   FPPA7 (void)
   goto   $;
void   Interrupt (void)
   pushaf;
   if (Intrq.T16)
   {   //   T16 Trig
      //   User can add code
      Intrq.T16   =   0;
   popaf;
/****************************************************************************************************///使用spwm_calc生成幅值61184,周内点数48(52),对称,半波模式,
void      zhengxianbo()      //正弦波
while(1)
 a1 =0x795D; b1 =0xE438; c1 =0x25D3; fuzhi(); yanshi();
// a1 =0x84C8; b1 =0xDF65; c1 =0x1DD4; fuzhi(); yanshi();
 a1 =0x9010; b1 =0xD998; c1 =0x16A9; fuzhi(); yanshi();
// a1 =0x9B1C; b1 =0xD2DD; c1 =0x1063; fuzhi(); yanshi();
 a1 =0xA5D0; b1 =0xCB46; c1 =0x0B11; fuzhi(); yanshi();
// a1 =0xB012; b1 =0xC2E4; c1 =0x06C0; fuzhi(); yanshi();
 a1 =0xB9CC; b1 =0xB9CC; c1 =0x037A; fuzhi(); yanshi();
// a1 =0xC2E4; b1 =0xB012; c1 =0x06C0; fuzhi(); yanshi();
 a1 =0xCB46; b1 =0xA5D0; c1 =0x0B11; fuzhi(); yanshi();
// a1 =0xD2DD; b1 =0x9B1C; c1 =0x1063; fuzhi(); yanshi();
 a1 =0xD998; b1 =0x9010; c1 =0x16A9; fuzhi(); yanshi();
// a1 =0xDF65; b1 =0x84C8; c1 =0x1DD4; fuzhi(); yanshi();
 a1 =0xE438; b1 =0x795D; c1 =0x25D3; fuzhi(); yanshi();
// a1 =0xE805; b1 =0x6DEB; c1 =0x2E92; fuzhi(); yanshi();
 a1 =0xEAC2; b1 =0x628E; c1 =0x37FE; fuzhi(); yanshi();
// a1 =0xEC6A; b1 =0x5761; c1 =0x41FF; fuzhi(); yanshi();
 a1 =0xECF7; b1 =0x4C7E; c1 =0x4C7E; fuzhi(); yanshi();
// a1 =0xEC6A; b1 =0x41FF; c1 =0x5761; fuzhi(); yanshi();
 a1 =0xEAC2; b1 =0x37FE; c1 =0x628E; fuzhi(); yanshi();
// a1 =0xE805; b1 =0x2E92; c1 =0x6DEB; fuzhi(); yanshi();
 a1 =0xE438; b1 =0x25D3; c1 =0x795D; fuzhi(); yanshi();
// a1 =0xDF65; b1 =0x1DD4; c1 =0x84C8; fuzhi(); yanshi();
 a1 =0xD998; b1 =0x16A9; c1 =0x9010; fuzhi(); yanshi();
// a1 =0xD2DD; b1 =0x1063; c1 =0x9B1C; fuzhi(); yanshi();
 a1 =0xCB46; b1 =0x0B11; c1 =0xA5D0; fuzhi(); yanshi();
// a1 =0xC2E4; b1 =0x06C0; c1 =0xB012; fuzhi(); yanshi();
 a1 =0xB9CC; b1 =0x037A; c1 =0xB9CC; fuzhi(); yanshi();
// a1 =0xB012; b1 =0x06C0; c1 =0xC2E4; fuzhi(); yanshi();
 a1 =0xA5D0; b1 =0x0B11; c1 =0xCB46; fuzhi(); yanshi();
// a1 =0x9B1C; b1 =0x1063; c1 =0xD2DD; fuzhi(); yanshi();
 a1 =0x9010; b1 =0x16A9; c1 =0xD998; fuzhi(); yanshi();
// a1 =0x84C8; b1 =0x1DD4; c1 =0xDF65; fuzhi(); yanshi();
 a1 =0x795D; b1 =0x25D3; c1 =0xE438; fuzhi(); yanshi();
// a1 =0x6DEB; b1 =0x2E92; c1 =0xE805; fuzhi(); yanshi();
 a1 =0x628E; b1 =0x37FE; c1 =0xEAC2; fuzhi(); yanshi();
// a1 =0x5761; b1 =0x41FF; c1 =0xEC6A; fuzhi(); yanshi();
 a1 =0x4C7E; b1 =0x4C7E; c1 =0xECF7; fuzhi(); yanshi();
// a1 =0x41FF; b1 =0x5761; c1 =0xEC6A; fuzhi(); yanshi();
 a1 =0x37FE; b1 =0x628E; c1 =0xEAC2; fuzhi(); yanshi();
// a1 =0x2E92; b1 =0x6DEB; c1 =0xE805; fuzhi(); yanshi();
 a1 =0x25D3; b1 =0x795D; c1 =0xE438; fuzhi(); yanshi();
// a1 =0x1DD4; b1 =0x84C8; c1 =0xDF65; fuzhi(); yanshi();
 a1 =0x16A9; b1 =0x9010; c1 =0xD998; fuzhi(); yanshi();
// a1 =0x1063; b1 =0x9B1C; c1 =0xD2DD; fuzhi(); yanshi();
 a1 =0x0B11; b1 =0xA5D0; c1 =0xCB46; fuzhi(); yanshi();
// a1 =0x06C0; b1 =0xB012; c1 =0xC2E4; fuzhi(); yanshi();
 a1 =0x037A; b1 =0xB9CC; c1 =0xB9CC; fuzhi(); yanshi();
// a1 =0x0B11; b1 =0xCB46; c1 =0xA5D0; fuzhi(); yanshi();
 a1 =0x1063; b1 =0xD2DD; c1 =0x9B1C; fuzhi(); yanshi();
// a1 =0x16A9; b1 =0xD998; c1 =0x9010; fuzhi(); yanshi();
 a1 =0x1DD4; b1 =0xDF65; c1 =0x84C8; fuzhi(); yanshi();
// a1 =0x25D3; b1 =0xE438; c1 =0x795D; fuzhi(); yanshi();
 a1 =0x2E92; b1 =0xE805; c1 =0x6DEB; fuzhi(); yanshi();
// a1 =0x37FE; b1 =0xEAC2; c1 =0x628E; fuzhi(); yanshi();
 a1 =0x41FF; b1 =0xEC6A; c1 =0x5761; fuzhi(); yanshi();
// a1 =0x4C7E; b1 =0xECF7; c1 =0x4C7E; fuzhi(); yanshi();
 a1 =0x5761; b1 =0xEC6A; c1 =0x41FF; fuzhi(); yanshi();
// a1 =0x628E; b1 =0xEAC2; c1 =0x37FE; fuzhi(); yanshi();
 a1 =0x6DEB; b1 =0xE805; c1 =0x2E92; fuzhi(); yanshi();
void      fuzhi()         //赋值
pwm0dtl      =a1 $0;      //先写
pwm0dth      =a1 $1;
pwm1dtl      =b1 $0;
pwm1dth      =b1 $1;
pwm2dtl      =c1 $0;
pwm2dth      =c1 $1;
void      yanshi()         //延时
word      yanshi_b1;
yanshi_b1      =yanshi_a1;
while(yanshi_b1--){}
//while(k_1){.delay 1000;if(k_2==0){a1--;fuzhi();}}      //定在这
//while(!k_1){.delay 1000;}
void      anjian()         //按键
if(k_1==0)
yanshi_a1++;
.delay 800;
if(k_2==0)
yanshi_a1--;
.delay 800;
Offline LovelyA72
  • Kashikoma from Massachusetts!
« Reply #1356 on: June 10, 2021, 09:24:38 am »
In case you didn't know, Suzhiming is that stm8stm8stm8 user on github.
A while ago I introduced FreePDK to him and seems like he's very interested in this project.
He is a Mini-C expert and he's a commercial MCU solution developer.
Btw: these variable names are in Chinese pinyin so they are only make sense to Chinese like us...  :-// but I am helping him with his English.
« Last Edit: June 10, 2021, 09:29:00 am by LovelyA72 »
Kashikoma!
Offline suzhiming
  • Country: cn
« Reply #1357 on: June 10, 2021, 09:30:40 am »
i 'm sorry very funny
Offline NickE
  • Country: hu
« Reply #1358 on: June 10, 2021, 06:46:18 pm »
This chip is also out of stock at LCSC.
Offline suzhiming
  • Country: cn
« Reply #1359 on: June 11, 2021, 01:30:59 am »
样片的话好办,工程的话还得分型号价格十倍(up*10)
Offline suzhiming
  • Country: cn
« Reply #1360 on: June 11, 2021, 01:34:54 am »
up mew touch mcu flash :pfc161
/*****************pfc161+tm1651********************/
/******************20210608************************/
/****************qq:774145445**********************/
/****************快手:共同学习stm8*****************/
//               _______    ______
//          dio-|1 pb7  \_/  pb010|-clk
//              |2 vdd       gnd 9|
//        cs-||-|3 pa7       pa0 8|-hong
//          tk8-|4 pa6       pa4 7|-lv
//          tk9-|5_pa5_______pa3_6|-lan
//       5v
//  pb0--clk
//  pb7--dio
//       gnd
#include   "extern.h"
tm1651_clk      bit      pb.0;
tm1651_dio      bit      pb.7;
byte      tm1651_a1;
void      tm1651_yanshi();      //延时
void      tm1651_start();         //起始信号
void      tm1651_data();         //数据
void      tm1651_ack();         //应答
void      tm1651_stop();         //结束
void   FPPA0 (void)
$      tm1651_clk      out,high;      //输出,高
$      tm1651_dio      out,high;
tm1651_yanshi();
while (1)
tm1651_start();
tm1651_a1   =0b0100_0000;   tm1651_data();      //写数据到显示寄存器,自动地址增加
tm1651_stop();
tm1651_start();
tm1651_a1   =0b1100_0000;   tm1651_data();      //设置地址00H
tm1651_a1   =0b1111_1111;   tm1651_data();
tm1651_a1   =0b0000_0000;   tm1651_data();
tm1651_a1   =0b0000_1111;   tm1651_data();
tm1651_a1   =0b1111_0000;   tm1651_data();
tm1651_stop();
tm1651_start();
tm1651_a1   =0b1000_1011;   tm1651_data();      //显示开,10/16
tm1651_stop();
//while(1){}
void      tm1651_yanshi()      //延时
.delay 100;
void      tm1651_start()         //起始信号
tm1651_clk   =1;   tm1651_dio   =1;   tm1651_yanshi();
tm1651_clk   =1;   tm1651_dio   =0;   tm1651_yanshi();
void      tm1651_data()         //数据
tm1651_clk      =0;   tm1651_yanshi();
if(tm1651_a1.0){tm1651_dio   =1;}   else{tm1651_dio   =0;}
tm1651_clk      =1;tm1651_yanshi();
if(tm1651_a1.1){tm1651_dio   =1;}   else{tm1651_dio   =0;}
if(tm1651_a1.2){tm1651_dio   =1;}   else{tm1651_dio   =0;}
if(tm1651_a1.3){tm1651_dio   =1;}   else{tm1651_dio   =0;}
if(tm1651_a1.4){tm1651_dio   =1;}   else{tm1651_dio   =0;}
if(tm1651_a1.5){tm1651_dio   =1;}   else{tm1651_dio   =0;}
if(tm1651_a1.6){tm1651_dio   =1;}   else{tm1651_dio   =0;}
if(tm1651_a1.7){tm1651_dio   =1;}   else{tm1651_dio   =0;}
tm1651_ack();
void      tm1651_ack()      //应答
$      tm1651_dio      in,pull;
tm1651_clk      =0;   tm1651_yanshi();      //第八个时钟的下降沿
while(tm1651_dio){nop;}
tm1651_clk      =1;   tm1651_yanshi();
$      tm1651_dio      out,low;
void      tm1651_stop()         //结束
tm1651_clk      =0;   tm1651_dio      =0;   tm1651_yanshi();
Offline spth
« Reply #1361 on: June 11, 2021, 05:25:18 pm »
Interesting....
The MF520, MF610 and MF616 all have 8 cores and 512 B RAM, and datasheets on the Padauk website. Unfortunately, these BLDC devices have very brief datasheets. Hope I can find a full PFC886 (or similar - if the MF520 is a PFC886 variant, there might be more PFC devices hidden behind PFC610 and PFC616) datasheet.
Offline Nominal Animal
« Reply #1362 on: June 12, 2021, 04:24:27 am »
Please use [CODE] /* Code goes here */ [/CODE], it will be easier to read.
请把[CODE]放在程序之前,[/CODE]放在程序之后。
Perhaps the following instead? 也许以下?
#include "extern.h"
byte     tm1651_byte;
#define  tm1651_send(b)   { tm1652_byte = b; tm1651_send_byte(); }
void  tm1651_start()
    .delay 100
    tm1651_dio = 0;
    .delay 100
void  tm1651_send_byte()
    byte  bits = 8;
    while (bits > 0) {
        tm1651_clk = 0;
        .delay 100
        SR      tm1651_byte$1
        SWAPC   tm1651_dio
        tm1651_clk = 1;
        .delay 100
        bits--;
    //等待确认
    tm1651_clk = 0;
    while (tm1651_dio) {
        nop;
    tm1651_clk = 1;
void  tm1651_stop()
    tm1651_clk = 0;
    tm1651_dio = 0;
    .delay 100
    tm1651_clk = 1;
    .delay 100
    tm1651_dio = 1;
    .delay 100
void   FPPA0 (void)
    .delay 100
    while (1) {
        //写数据到显示寄存器,自动地址增加
        tm1651_start();
        tm1651_send(0b0100_0000);
        tm1651_stop();
        //设置地址00H
        tm1651_start();
        tm1651_send(0b1100_0000);
        tm1651_send(0b1111_1111);
        tm1651_send(0b0000_0000);
        tm1651_send(0b0000_1111);
        tm1651_send(0b1111_0000);
        tm1651_stop();
        //显示开,10/16
        tm1651_start();
        tm1651_send(0b1000_1011);
        tm1651_stop();
I'm not sure, though, because I do not have any Padauk MCUs, or the Padauk Mini-C compiler; I am just guessing...
I much prefer sdcc.
Offline suzhiming
  • Country: cn
« Reply #1363 on: June 12, 2021, 06:50:36 am »
IDE0.91: http://www.padauk.com.tw/cn/technical/index.aspx?kind=36
单核:Single core processor    :PMS150G,152,154
WITH TOUCH:                      :PMS161,PMS164(FLASH):PFC161
双核:Dual Core Processor      :PMC232,PMC234(FLASH):PFC232
八核:Eight core processor      :(FLASH):PFC886
Offline suzhiming
  • Country: cn
« Reply #1364 on: June 12, 2021, 07:06:39 am »
new*new*new*
video:https://www.bilibili.com/video/BV1Bw411Z7fN?from=search&seid=6609710309287088602
//               _______    ______
//              |2 vdd       gnd 9|
//       5v
//  pb0--clk
//  pb7--dio
//       gnd
#include   "extern.h"
byte      tm1651_a1;
void   FPPA0 (void)
//0x7f;0x30;0x6d;0x79;0x33;0x5b;0x5f;0x70;0x7f;0x7b;0x77;0x1f;0x4e;0x3d;0x4f;0x47;
tm1651_yanshi();
while (1)
tm1651_start();
tm1651_stop();
tm1651_start();
tm1651_a1   =0x7e;tm1651_data();
tm1651_a1   =0x30;tm1651_data();
tm1651_a1   =0x6d;tm1651_data();
tm1651_a1   =0x79;tm1651_data();
tm1651_stop();
tm1651_start();
tm1651_stop();
//while(1){}
.delay 100;
tm1651_ack();
Offline suzhiming
  • Country: cn
« Reply #1365 on: June 12, 2021, 08:13:18 am »
@js_12345678_55AA
mf520data:http://www.padauk.com.tw/cn/product/show.aspx?num=139&kw=520
English:http://www.padauk.com.tw/upload/doc/MF520%20datasheet_EN_V003_20210115.pdf
China:http://www.padauk.com.tw/upload/doc/MF520%20datasheet_CN_V003_20210115.pdf
pfc886 data Chinese only  E-mail:suzhiming@88.com
Offline suzhiming
  • Country: cn
« Reply #1366 on: June 12, 2021, 08:47:14 am »
@js_12345678_55AA
This is unpublished data.
E-mail To you.or** 如有业务或工程应用问题, 欢迎联络我司业务窗口 Kevin Liu : kevin_liu@padauk.com.tw **
new:MCS11
http://www.padauk.com.tw/cn/product/show.aspx?num=79&kind=85
http://www.padauk.com.tw/upload/doc/MCS11_datasheet_v0%2020_20180420.pdf
  • Country: ht
« Reply #1367 on: June 12, 2021, 01:20:53 pm »
@js_12345678_55AA
new:MCS11
@suzhiming: 你可以给我发个邮件,js55aa@88.com
Offline suzhiming
  • Country: cn
« Reply #1368 on: June 13, 2021, 09:13:37 am »
//               _______    ______
//              |2 vdd       gnd 9|
//       5v
//  pb0--clk
//  pb7--dio
//       gnd
#include   "extern.h"
byte      tm1651_a0;
byte      tm1651_a1;
byte      tm1651_a2;
byte      tm1651_a3;
byte      tm1651_a4;
void      tm1651_xianshi();      //显示
void      yanshi()
.delay 1000000;
void   FPPA0 (void)
//0x7e;0x30;0x6d;0x79;0x33;0x5b;0x5f;0x70;0x7f;0x7b;0x77;0x1f;0x4e;0x3d;0x4f;0x47;
while (1)
tm1651_a1      =0x7e;
tm1651_a2      =0x30;
tm1651_a3      =0x6d;
tm1651_a4      =0x79;
tm1651_xianshi();
yanshi();
tm1651_a1      =0x33;
tm1651_a2      =0x5b;
tm1651_a3      =0x5f;
tm1651_a4      =0x70;
tm1651_xianshi();
yanshi();
tm1651_a1      =0x7f;
tm1651_a2      =0x7b;
tm1651_a3      =0x77;
tm1651_a4      =0x1f;
tm1651_xianshi();
yanshi();
tm1651_a1      =0x4e;
tm1651_a2      =0x3d;
tm1651_a3      =0x4f;
tm1651_a4      =0x47;
tm1651_xianshi();
yanshi();
.delay 50;
if(tm1651_a0.0){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;      //太快检测不到需要加延时
if(tm1651_a0.1){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
if(tm1651_a0.2){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
if(tm1651_a0.3){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
if(tm1651_a0.4){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
if(tm1651_a0.5){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
if(tm1651_a0.6){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
if(tm1651_a0.7){tm1651_dio   =1;}   else{tm1651_dio   =0;}
nop;nop;nop;
tm1651_ack();
byte      tm1651_ack_a1;
tm1651_ack_a1      =0;
while(tm1651_dio==1)      //检测低电平
   tm1651_ack_a1      ++;
   if(tm1651_ack_a1>150)      //退出条件(死机)
      return;
void      tm1651_xianshi()      //显示
tm1651_start();
tm1651_a0   =0b0100_0000;   tm1651_data();      //写数据到显示寄存器,自动地址增加
tm1651_stop();
tm1651_start();
tm1651_a0   =0b1100_0000;   tm1651_data();      //设置地址00H
tm1651_a0      =tm1651_a1;   tm1651_data();
tm1651_a0      =tm1651_a2;   tm1651_data();
tm1651_a0      =tm1651_a3;   tm1651_data();
tm1651_a0      =tm1651_a4;   tm1651_data();
tm1651_stop();
tm1651_start();
tm1651_a0   =0b1000_1011;   tm1651_data();      //显示开,10/16
tm1651_stop();
Offline suzhiming
  • Country: cn
« Reply #1369 on: June 14, 2021, 06:33:24 am »
thi is assembler And hex,bin  contact
这个是汇编完的效果,asm文件是怎么转换成.bin烧录文件的,这一步是由烧录器完成的
« Last Edit: June 14, 2021, 06:42:45 am by suzhiming »
Offline suzhiming
  • Country: cn
« Reply #1370 on: June 16, 2021, 10:47:08 am »
It's not a human habit
  • Country: ht
« Reply #1371 on: June 17, 2021, 08:49:11 pm »
PFC232 write support now uses the "Limited Voltage writing". This makes it possible to use the standard easy-pdk-programmer without modifications.
I also added support for PFC151 and PFC161 ... which are *surprise surprise* ... the *SAME IC*.
Even original writer can write a PFC151 when a PFC161 program is loaded.
JS
Offline spth
« Reply #1372 on: June 18, 2021, 08:07:45 am »
Looking at the datasheets, the PFC161 one was created by copying the PFC151 one, changing "PFC151" to "PFC161" (though they forgot two places that still have "PFC151") and adding section 11.2 for the capacitive touch peripheral.
I wonder if the PFC161 is a PFC151 with the cacitive touch peripheral added vs. the PFC151 being a PFC161 where the capacitive touch peripheral failed test.
  • Country: ht
« Reply #1373 on: June 18, 2021, 01:11:40 pm »
...  failed test ...  :-DD :-DD :-DD  What test? Many Padauk data sheets speak about "yield" at programing... basically the customer is doing the test.
Anyway, I will create a small test project to find out. My guess... it is just a marketing variant.
JS
« Last Edit: June 18, 2021, 01:14:24 pm by js_12345678_55AA »
Offline suzhiming
  • Country: cn
« Reply #1374 on: June 19, 2021, 05:42:18 am »
