That multi-meter stand would have looked a lot better if it was in light blue , the same color as the GW meter Also that would be real nice
as a accessory item if you sold it along side with the multi-meter .
Go to the video turn on closed captions and read what Sagan apparently says I’m the first 30 seconds or so
Looks like that calculator was a rush attempt to hack something new from the existing design. Got the existing board designs from the previous model, slapped a clumsy cable to connect a display from a different vendor. Attached the IR interface and battery on the separate boards form factor adapter boards. Ready to ship.
After all, the customers aren't expected to see all that mess inside.
Yes, the figurine is of an anime character, Sugiura Ayano from Yuru Yuri.
That's just the software not coping with an Australian accent. It struggles on 'The Signal Path' as well because Sharier talks too fast.
