Author Topic: EEVblog #1289 - Mystery Huawei Teardown  (Read 6738 times)
Offline EEVblogTopic starter
« on: March 05, 2020, 02:59:24 am »
Mystery Mailbag Teardown!
Huawei make WHAT?
Subscribe on Library: https://lbry.tv/$/invite/@eevblog:7
The following users thanked this post: johnlsenchak
Offline Brumby
Re: EEVblog #1289 - Mystery Huawei Teardown
« Reply #1 on: March 05, 2020, 03:36:41 am »
Those PSU caps ....  Ranghai  (never heard of them myself)
« Last Edit: March 05, 2020, 03:38:29 am by Brumby »
Offline johnlsenchak
  • js@antihotmail.com
    • paypal.me/johnsenchak
« Reply #2 on: March 05, 2020, 05:22:58 am »
Congratulation  for  getting over  ten  thousand   subscribers  on that  website.  I so  happen to be one of them  ! 8)
Huawei    has been  banned in the United  States   something   to do with their   equipment  being  a network  monitor  for the   Chinese  government. So here in the good  old  USA ( Not   Aussie )   we don't  see any of their products, no cell  phones or  networking  equipment
 All those  PC  boards in that unit  are  "Sex on a  Stick"
A good  video  idea is  trying to de-solder  those  high priced  power supplies  off the main  board
John Senchak "Daytona  Beach  Florida "
 jls (at)  antihotmail.com   http://www.antihotmail.com
https://www.facebook.com/john.senchak.1
Offline Brumby
« Reply #3 on: March 05, 2020, 06:31:33 am »
My mistake.
Still haven't heard of it before.
Offline G7PSK
  • It is hot until proved not.
« Reply #4 on: March 05, 2020, 09:08:21 am »
I have found the best way of removing units like those power boards providing you dont want the main board they are on is to use a miniature diamond core drill. These are meant for drilling tiles and glass and are available in sizes down to four millimeter. I cut out the via on each leg then you can either easily de solder or if they are tight on the pins sand the remains down to the pins.
Offline G7PSK
« Reply #5 on: March 05, 2020, 09:42:49 am »
The last thing I want is to drill or grind FR4, especially considering how hard face masks are to come by. I'd rather pan fry the board with vegetable oil than to drill and cut the board.
Absolutely no problem with dust, just like drilling glass or tiles you use a bit of paraffin or dish washing liquid,keeps the dust down and lubricates the cutter making it last longer.
Offline bsdphk
« Reply #6 on: March 05, 2020, 11:54:01 am »
The reason milling FR4 is not recommended is that it dulls the routing bits in no time.
Offline G7PSK
« Reply #7 on: March 05, 2020, 11:58:31 am »
Not a problem with diamond cutters.
Offline briangordon
« Reply #8 on: March 05, 2020, 12:34:01 pm »
You can get a Huawei phone if you want one, but telecoms can't use their equipment and Google can't license the Play Store or Maps, Gmail, etc to them so it will have weird Chinese knockoff versions of the apps.
Online Monkeh
« Reply #9 on: March 05, 2020, 03:00:39 pm »
The connectors aren't custom - they're standard backplane connectors. https://www.digikey.com/product-detail/en/amphenol-icc-fci/51722-10201200ABLF/609-5060-ND/5802588 on the fan module, for example. Absolutely every day normal part on this sort of equipment.
Yes, thank you so much for that.
Offline Fryguy
« Reply #10 on: March 05, 2020, 07:51:32 pm »
Hi Dave , i noticed on the board with the 9 big chips that only 8 of them are sitting right next to a pair of memory chips ! The one in the middle has no memory and a different set of peripheral parts underneath it - so this must be something else . There you have your 8 channels and one other chip probably doing some interfacing .  :-/O
« Last Edit: March 05, 2020, 08:01:41 pm by Fryguy »
Born error amplifier  >.<
Offline ckambiselis
« Reply #11 on: March 06, 2020, 04:55:55 pm »
About the press fit power connectors, I work in custom made vehicle manufacturing, the bus size type, and the main power distribution boards we currently use, have the same type, first time I saw them I thought the maker was cutting on cost by not soldering them, since the boards are all connectors and huge traces to distribute the signals, but I guess they are normal, haven't heard from the older folks that they have had any vehicle come for repairs because of them, even though all the cabling connections we make must be shakeproof.
Oscar
Offline chris_leyson
  • Country: wales
« Reply #12 on: March 06, 2020, 06:16:41 pm »
Thanks for the teardown Dave, nice to see a very well designed piece of equipment with no expense spared.
Online gamalot
  • Correct my English
    • Youtube
Online gamalot
    • Youtube
« Reply #14 on: March 06, 2020, 07:28:04 pm »
Jianghai, they used to be a Chinese military factory making capacitors, then went private during China's company reform (state owned companies became private or public).
They had joint venture with Hitachi and Elna, and they used their technology to build equivalent models to Rubycon, Nichicon and Chemicon (they all have cross reference to each other).
You missed an American company.  :)
http://newsroom.kemet.com/news-releases/news-release-details/kemet-announces-chinese-manufacturing-joint-venture
Offline thm_w
  • Non-expert
« Reply #15 on: March 09, 2020, 09:43:55 pm »
Oscar
Think about all the garbage lead-free solder joints we've seen that have cracked, due to thermal cycling or vibration. A properly made press-fit connection is probably far more reliable.
https://www.connectorsupplier.com/press-fit-connectors-in-harsh-automotive-applications/
