Author Topic: EEVblog 1423 - Magic Repair Smoke  (Read 3472 times)
Online EEVblogTopic starter
« on: October 02, 2021, 05:45:31 am »
Dave released the magic smoke during a repair!
Brain was not engaged...
00:00 - Alien LED driver
01:34 - New microscope measurment setup!
02:46 - Teardown
07-45 - Brown Black Burnt
09:31 - This sucks!
16:08 - BANG!
18:49 - It seemed reasonable at the time...
19:41 - Reverse Engineering
Offline Neilm
Re: EEVblog 1423 - Magic Repair Smoke
« Reply #1 on: October 02, 2021, 06:08:46 pm »
Humm - Trap for old players there... I wonder how many other old players have made an assumption and got things totally wrong (I know I have)
I would have been weary of using it even if it had been repaired - if the resistor got so hot it delamminated the PCB who knows what else had been stressed / damaged due to it.
At least you gave it a Viking funeral
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
The following users thanked this post: highlanderIII
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: October 03, 2021, 08:46:03 pm »
Looks like confirmation bias strikes again.
Offline ssander
« Reply #3 on: October 03, 2021, 11:38:06 pm »
Dave,
In your video Astable Aliens, you had a potential known good reference i.e. another light.   |O
Offline sean0118
« Reply #4 on: October 04, 2021, 01:27:46 am »
I think there must have been something else wrong with it anyway, maybe the 180k was short putting the full rectified voltage across the failed resistor?
This was a much better option than putting it in the bin first, if only Dave setup a slow motion camera. I wouldn't mind if he plugged it in a second time actually.  :popcorn:
Also, really surprised there doesn't seem to be an input fuse, unless those input resistors are the fusible type?
« Last Edit: October 04, 2021, 01:29:23 am by sean0118 »
Offline golden_labels
« Reply #5 on: October 04, 2021, 03:53:06 am »
Put a tape over the button while filming scenes of devices being powered on! ;)
People imagine AI as T1000. What we got so far is glorified T9.
Offline BrokenYugo
« Reply #6 on: October 04, 2021, 04:34:25 am »
I was under the impression that fusible resistors are flameproof...
The following users thanked this post: jpwolfe31
Online Kleinstein
« Reply #7 on: October 04, 2021, 06:32:55 am »
With the input resisors there is no real need for another fuse.
Chances are the one small resistor under the shlieve that Dave first considered a fuse may be a fusibel resistors.  However the other 4 were faster.
Offline thm_w
  • Non-expert
« Reply #8 on: October 04, 2021, 08:16:20 pm »
Dave,
Probably too much work to take it down, but that would have been ideal.
Thats what he said, the value was very low, 0.1R.
Offline jonovid
    • JONOVID
« Reply #9 on: October 06, 2021, 07:40:08 am »
 :palm: holy moly even yt blogger Big Clive knows the value of reverse engineering a two layer pcb ,   :o
looks like too much in a hurry to get the video out & uploaded. when more time is needed to get the job completed.
the need to keep it always live! can be a trap.  for all players.
Big Clive has a saying when not prepared or unsure    one moment please....  then pauses the video.
how many pro bloggers can not or will not pause the video to get a complicated task done off camera that is too mundane for live video.
in spite of having all the tools at hand to do any reverse engineering task. even the most complicated if enough time is taken.
maybe Dave should do a video on time management skills when blogging , forward planning skills.
I had to learn the hard way when it came to posting home DIY video.  |O
as for Me posting video is 90% forward planning, 9% editing & 1% time uploading the video if its ok.
otherwise go back & repeat steps 1 2. till its ok  ;D
« Last Edit: October 06, 2021, 08:14:48 am by jonovid »
Hobbyist with a basic knowledge of electronics
Offline sean0118
« Reply #10 on: October 06, 2021, 08:25:36 am »
Well they did fuse...   in a way  :P
Offline Johnny10
« Reply #11 on: October 06, 2021, 03:09:31 pm »
Makes you think  :-[ about "right to repair"!
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
« Reply #12 on: October 07, 2021, 06:05:47 am »
Dave and Big Clive have a different target audience. I would not expect Dave to dedicate his time to reverse engineering an already unusable trivial PSU on expense of other videos. Unless he finds a time generator machine or a human duplicator in the dumpster.
There is a solution, though. The next “alien” PSU, if it experiences an identical failure, may be sent to Big Clive. Everyone will be happy.
