Author Topic: EEVblog 1607 - PSU Switching Noise Reduction via Vibration  (Read 37479 times)
Online EEVblogTopic starter
« on: March 31, 2024, 09:58:14 am »
Physically vibrating your power supply at a sub harmonic of your PSU switching frequency can potentially lower your system noise. A practical demonstration.
The following users thanked this post: egonotto, Fungus, Brumby, pdenisowski, SiliconWizard
Offline isometrik
Re: EEVblog 1607 - PSU Switching Noise Reduction via Vibration
« Reply #1 on: March 31, 2024, 02:49:58 pm »
That effect is known as the fishbowl effect in the literature.
Offline Xena E
« Reply #2 on: March 31, 2024, 05:31:57 pm »
What a Cock :palm:
Gave me a laugh though... keep it up!  :-+
  :popcorn:
Offline tszaboo
« Reply #3 on: March 31, 2024, 06:03:04 pm »
You have to be really careful to avoid the resonance cascade. Especially if you are working with the Anti-Mass Spectrometer.
The following users thanked this post: T3sl4co1l
Offline .RC.
« Reply #4 on: April 01, 2024, 03:54:25 am »
Easier to just go full Star Trek and change the polarity of the ODN junctions.   ;D
Offline golden_labels
« Reply #5 on: April 01, 2024, 10:13:51 am »
It’s a well known among IT experts method of reducing fan and disks vibration. Electrolyte in PSU’s smoothing capacitors crystalizes and the capacitor starts exhibiting a dip in conductance at specific frequencies. In general it’s not a problem and, where it is, manufacturers employ spectrum spreading (you may recall this advertised on your old mobos). But it remains a problem in devices which rotate at fixed speeds, like computer fans and HDDs. Disks are particularly vulnerable, because their high inertia keeps the spinning frequency constant. Hitting the computer case in the right way produces enough of higher harmonics to make crystals in capacitors to break down, restoring unrestricted flow of energy.
Dave is wrong on one thing: you can deliver MHz range vibrations. This is what medical ultrasonography uses. The reason it doesn’t work for reducing spikes is the wavelength. Sound wave at 10 Mhz has wavelength of 1 mil, that is less than a thickness of US dollar bill. The wave passes through the capacitors and inductors as if they weren’t there, instead of being absorbed.
Why 📎 | We live in times when half of people have IQ below 100.
Online pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #6 on: April 01, 2024, 02:36:45 pm »
This was actually the subject of an IEEE paper
« Last Edit: April 01, 2024, 02:39:39 pm by pdenisowski »
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: EEVblog, egonotto, thm_w, alm
« Reply #7 on: April 01, 2024, 10:21:57 pm »
That must be the one I read  :-+
« Last Edit: April 01, 2024, 10:24:56 pm by EEVblog »
Offline SiliconWizard
« Reply #8 on: April 01, 2024, 11:41:48 pm »
Excellent!  :-+
« Reply #9 on: April 01, 2024, 11:49:34 pm »
Well, that's the whole concept of acoustic black holes. :P
« Reply #10 on: April 02, 2024, 12:03:45 am »
Correct. At Thales we used to do MHz range phased array sonar, it just passes right through.
Offline egonotto
« Reply #11 on: April 02, 2024, 08:16:00 am »
Hello,
it is fitting that the authors of the article are called First and April in Polish.
Best regards
egonotto
Offline Keri Szafir
  • the vacuum tube witch!
    • youtube
« Reply #12 on: April 02, 2024, 09:48:43 am »
...from the Beaver University! Pet that beaver and try once again just to see if it was not a Fluke.
I'm Polish and haven't even noticed, LOL.
...its loveliness increases, it will never pass into nothingness
Keritech Electronics - building vacuum tube amps and restoring vintage gear since 2004!
Online Ranayna
« Reply #13 on: April 02, 2024, 12:31:41 pm »
I have to admit: You got me :D
I know that you always post these videos. Yesterday i actually thought that i might have missed it due to the Algorithm.
Now i read this thread, and yet again i had to realize: Damn, you Australians are early :D I did not miss the video, it totally flew over my head. :palm:
But while your earlier videos were obvious, this got me...
Offline strawberry
  • Country: lv
« Reply #14 on: April 02, 2024, 05:42:49 pm »
oscillators may run off
