Author Topic: EEVblog 1650 - Sequre HT-140 SMD Desoldering Tweezers REVIEW  (Read 43289 times)
Offline I.T. Manager
Re: EEVblog 1650 - Sequre HT-140 SMD Desoldering Tweezers REVIEW
« Reply #25 on: November 26, 2024, 12:28:27 am »
Menu item OLED lets you select 0/180 degrees display direction.
Thank you kind sir, I will put my order in for one ASAP.   ;D
Once heard years ago "My 95 Windows are broken"
Offline ceut
« Reply #26 on: November 28, 2024, 09:37:29 am »
I have received mine some minutes ago.
FW 1.03 too.
After making some adjustement on tweezer, and setup some items in the menu+voltage calibration (+0.2V offset for mine - checked with my Keysight U1232A DMM): I find this really a great tool after testing removal of some SMD caps and R :-+
It is super fast for that task  :D
Menu items are not so hard after understanding the 5s timeout for waiting to go back.
But I have some T° overshoot showing on the Oled screen like we can see on the Dave review, but not as big as in the video, don't know if it is a bug with having 2 sensors, or real overshoot ? I will try to check that back home.
Also, I have not found support page on the Sequre website for downloading firmware of this HT-140.
So I don't know how the 1.02FW user could upgrade their tweezers  :-\
Edit:
>About 2 to 5°C  off so it is good, will try to calibrate it later.
>All is grounded to USB-C and DC ground. About 100VAC between tips and mains ground. Will try also to put the mains ground on negative, but I have to check the leakage current before.
>Positive DC Jack is also the positive USB-C, so we can also power directly from USB-c at any voltage without having a PD or any other handshake protocol negociation.
  I already do this with my MHP30 hotplate ;)
Edit2: Youtube video on my little chanel here:    :-+
« Last Edit: March 31, 2025, 10:09:21 am by ceut »
Offline ceut
« Reply #27 on: November 29, 2024, 04:32:20 pm »
So I have checked the current leakage from DC GND to Earthground: very very low 0.27mA on U1272A which has a low burden voltage :-+
I have also checked the USB-C cable which was in the package with the superb japanese USB tester: great quality with 147milliOhms :-+
=>The simpliest way to ground the HT-140 is to take a spare used USB-A cable and put the Negative DC and Shield to the AC Earthground : it will put the USB-C to Earthground too directly from the Sequre PSU  8)  (that(s what I have done for testing, and will made that more permanent)
Here are photos as always  :D
« Last Edit: November 29, 2024, 04:40:08 pm by ceut »
Offline W00fer
« Reply #28 on: December 03, 2024, 07:24:02 pm »
Sequre is working on adjustable motion sensor support in firmware to come.
For me it's very sensitive now.
Offline ceut
« Reply #29 on: December 03, 2024, 08:15:37 pm »
Great to read that, same thing for me: the sensor setting is wayyy too sensitive  :palm:
Also, I have made my first video of my HT-140 in real use, and also with my new camera  :-+
Here is the short video:
« Last Edit: December 03, 2024, 08:24:44 pm by ceut »
Offline W00fer
« Reply #30 on: December 04, 2024, 01:48:16 am »
Nice video. I hope you will work out the manual focus if possible.
Sequre can do a lot more with the firmware but it's upto us to ask them. Since there is a steep language barrier I might suggest bugs and features also in Chinese to them. Albeit with Google translate.
Offline ceut
« Reply #31 on: December 04, 2024, 06:55:33 am »
Thank you  :)
For the focus, yes I saw it after reviewing the video on my computer.
In fact, the camera has tried to focus sometimes on my glove  :-\
I have actived the tracking mode, and targetting the PCB (this one works as we can see in the video that the camera is moving its head alone  :-+ )
I think that when the camera lost the tracking of the PCB, it tries to focus on the closest item when the tracking object is lost  ???
Will try to do better next time (with manual focusing I think)  :)
For firmware improvement, I have to send a mail to Sequre to add the PowerON sensor mode, as I have (and always use) with IronOS on my TS-100.
=>This mode heats up when I take it up from the cradle, from room temperature, without doing any action on A/B buttons, and only after powering the unit.
Edit: Mail sent to Sequre contact support with this improvement firmware proposal :-+
Hope they will reply me :)
(it is this setting on IronOS of my TS-100: https://ralim.github.io/IronOS/Settings/#setting-start-up-behavior , set to "R=standby, heat-off until moved" )
« Last Edit: December 04, 2024, 11:20:27 am by ceut »
Offline ceut
« Reply #32 on: December 05, 2024, 11:53:53 am »
Attached is a picture of the mod i made to the Sequire S99 C245 iron. I marked it up where i cut fully through the PCB (and taped over with kapton tape), and then reconnected the 3 terminals in (what my research suggested) is the correct pinout. There is some confusion around the net about the pinout, so double check it. But yeah, my tip no longer jumps between 0V and 20V (referenced to USB GND) while the iron is running!
[edit] Looking at the mod again now, i've made a pretty big hot loop for the switching power through the tip in my haste to GND the tip properly. You might be better off tying the GND wire in as close to the SO-8 mosfet as possible as well. I might be overthinking it though, it seems to work.
The Sequire S60P C210 was connected correctly as far as i could tell, and the all metal L245 usb-c iron i ordered from aliexpress some other time also has the correct pinout (ie tip is connected to the USB-C shield). I've added a phote of all three below as well.
I like the idea of just using a power bank, although with the really big tips i have seen these USB-C irons go up to 120W during initial heatup! And i'm sure that whenever i really needed to solder something i'd realise that i'd forgotten to charge the power bank 😅
Hello,
Thank you for poiting this  :-+
I have received my S99 this morning, and I have 5.5Ohms between the tip and the USB-C shield  :palm:
The rear screw is also connected to the tip, so 5.5Ohms too between this screw and USB-C shield.
So completely different from the HT-140, where (I think) they have fixed this.
I have the latest board 1.5 version into it (it is showing it in the menu)
HW version: 1.5
SW version: 1.08
So I have to fix that too  :-BROKE
Question: Is there any problem with the feedback of the thermocouple  (negative voltage value) after the mod ?  ???  Thank you  :)
Edit: I have found a russian guy who has done a great job with all JBC pinout analysis cartridge here:
http://adgd.ru/2021/01/04/jbc-soldering-cartridges-pinouts/
Edit2: I found "my way" to fix this, and have opened a new topic S99 here: https://www.eevblog.com/forum/reviews/sequre-s99-topic-mod-infos/msg5741905/#msg5741905  :)
« Last Edit: December 23, 2024, 06:02:55 pm by ceut »
Offline W00fer
« Reply #33 on: December 05, 2024, 05:47:16 pm »
Someone dumped the HT140 1.03 firmware on IronOS github, made rudimentary pinouts and took photo's of the PCB.
So I hope either the features he requested are forwarded to Sequre team or are made available in IronOS.
Firmware is 64kb and the rest is available space.
Offline Demon Xanth
« Reply #34 on: December 19, 2024, 09:02:10 pm »
Something I've noticed with mine:
Though it says it can do PD140, I have yet to see it request more than PD60. Even with a PD240 cable and PD100 and PD140 supplies. My PD140 battery bank wouldn't negotiate with it at all. (but then it also had issues with my DHO804, so I blame Baesus on that one).
Removing some SMT electrolytic caps from some boards and SMC sized diodes, it worked very well though!
Edit:
I found the menu options. I'm a dingus.
« Last Edit: December 20, 2024, 04:18:09 pm by Demon Xanth »
Offline W00fer
« Reply #35 on: December 26, 2024, 05:20:09 pm »
Sequre needs 2 things in this firmware
If you connect a 100w charger 20v 5A and then a 15v 3a (45w) charger it bootloops until you change the setting in the menu.
Also if you disconnect one of the tips it goes constantly into beeping error, until you plug it back in and turn it off in the menu.
It should fallback to one only if the other isn't connected.
Offline W00fer
« Reply #36 on: January 02, 2025, 02:09:32 am »
It seems that the 3 and 5 mm wide C210 addons are only manufactured by Sequre?
Anyone got another link for them?
Offline atroz
« Reply #37 on: January 02, 2025, 07:53:07 pm »
YIHUA has some that look the same.  I ordered them yesterday because AliExpress offered free shipping on them but not the Segure ones.  Will take a week or more for them to arrive and see if I made a mistake or not.   https://www.aliexpress.com/item/1005008269476408.html
The following users thanked this post: W00fer
Offline W00fer
« Reply #38 on: January 03, 2025, 12:46:06 am »
Thanks a lot. I tried to find these but only found C245 ones.
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #39 on: January 03, 2025, 04:37:14 pm »
I have these tweezers, but didn't like the lack of earth ground on the PSU which was generating 104Vrms / 335Vp-p on the tips!
......so did something about it:
https://youtu.be/se6-jGZsHS0
Ian.
Website: www.ianjohnston.com
Offline W00fer
« Reply #40 on: January 06, 2025, 06:04:18 pm »
Do these tweezers require 20v exact or is 19.5 also okay?
I have a 180W Dell power supply for a laptop that does 19.5v 9.23A
Model HA180PM180
Are the amps limited to 5?
Manual indicates it should be 28v 5A for 140W but this could be firmware limited?
« Last Edit: January 06, 2025, 06:15:23 pm by W00fer »
Offline W00fer
« Reply #41 on: January 06, 2025, 06:26:23 pm »
Ian.
Would this be a solution? Just connect a wire from the tweezers to this plug.
Offline edavid
« Reply #42 on: January 06, 2025, 08:20:44 pm »
For those in the US, it looks like the current lowest price is from newegg @ $89.99 with free shipping (ends 1/11/25).
https://www.newegg.com/p/0J6-00Z1-00043
If you order from sequremall.com, there is a discount code SQ8 that gives 8% off, but there is a shipping charge.  I think it's still less than AliExpress though.
https://sequremall.com/products/sequre-ht140-2in1-hot-tweezers-soldering-iron-desoldering-repair-tool-for-smd
P.S. Where can I download the manual?
« Last Edit: January 07, 2025, 03:27:58 pm by edavid »
Offline W00fer
« Reply #43 on: January 07, 2025, 08:06:57 pm »
Manual is on page 1 of this topic, in one of the first posts. Aliexpress pricing is mostly only interesting on sales like Halloween, Christmas, Black Friday and 11.11
They won't cover customs duties so the Sequre shop is cheaper (and Newegg).
Offline atroz
« Reply #44 on: January 14, 2025, 12:58:51 am »
Received them today.     They work.
Offline W00fer
« Reply #45 on: January 15, 2025, 01:15:34 am »
Ordered the 5.0 C210 irons from Sequre, I might order the 3.0 ones from Yihua later to compare.
In the world of soldering SMD the bigger iron the better (only if it doesn't reach it you need smaller) so to wick off the components the 5.0 should do.
Changing the two irons is a true pain. The four super small bolts that hold the irons are easily gone from your table.
They really need to have a better system for that. A locking ring or something else.
Offline GeraYr
« Reply #46 on: February 01, 2025, 06:53:50 am »
I ordered and received YIHUA C120-3.0D mm from AliExpress "Pro cellphone repair Store" - they are special for tweezers. I have never bought such junk before. One tip is practically unsuitable for work. Almost 27€ for two soldering tips of very questionable quality is too high a price. Sequre (sequremall.com) now you can buy them too, they have expanded their range.
« Last Edit: February 10, 2025, 08:03:43 am by GeraYr »
The following users thanked this post: thm_w, edavid
Offline W00fer
« Reply #47 on: February 05, 2025, 02:48:10 pm »
I received the C210 ones from MaAnt from Aliexpress and they are pretty nice quality.
Sadly they don't have the wide ones from Sequre or Yihua.
See attachment.
Cost about 4.50 euro a piece.
Offline thikone
  • Country: at
« Reply #48 on: February 06, 2025, 11:58:41 am »
Anyone can recommend a DC5525 power supply that is not a fire hazard? Thought of using an Asus laptop one but it's 19 volts not 20 as the iron will expect.
It's the only 120W adapter I have. 140W will be harder to find.
SlimQ F150, the one that has UCB-C but also DC5525 jack! It works with tweezers, and (!) it can drive C245 tips in S99 to full power! There is also nice silicon cable that feels like JBC handpiece cable from AliExpress:https://www.aliexpress.com/item/1005005865036528.html
Andrey Kharitonkin
Offline W00fer
« Reply #49 on: February 06, 2025, 08:26:39 pm »
It seems that it also outputs 19.5 and not 20?
Max 150W Output (19.5V-20V)
https://slimq.life/products/150w-usb-c-gan-charger-for-universal
In the PDF it states 20V 7.5A on DC
https://slimq.life/pages/150w-gaming-laptop-charger-specifications
Is that where the voltage compensation is for?
Does anyone know what the voltage compensation is? The manual doesn't say anything specific about it.
« Last Edit: February 06, 2025, 08:40:20 pm by W00fer »
