Author Topic: EEVblog 1667 - Reverse Engineering the Brymen BM2257 Multimeter  (Read 7961 times)
Offline EEVblogTopic starter
« on: February 10, 2025, 08:56:56 pm »
Reverse Engineering the Brymen BM2257 Multimeter front end to understand what changes have been made from the BM235 in the Low Z mode. DaveCAD time. Also some testing of the LowZ mode.
The following users thanked this post: jebem
Online SiliconWizard
Re: EEVblog 1667 - Reverse Engineering the Brymen BM2257 Multimeter
« Reply #1 on: February 11, 2025, 04:00:49 am »
What a bobby-dazzler! ;D
Offline Kleinstein
« Reply #2 on: February 11, 2025, 10:08:35 am »
Nice video. I think the ohms mode is reading back the actual voltage not via the 10 M resistor, but though a path (still a few parts missing) from the very bottom Q1+Q8 transitor clamp. They need the 2 PTC paths separate: one to drive a current and the other to read back the voltage. One can not measure resistance with just 1 PTC in series.
« Reply #3 on: February 11, 2025, 11:43:21 pm »
Quite possible.
Offline SteveLTN
  • Country: cn
« Reply #4 on: February 12, 2025, 11:42:39 am »
Ha I always thought the 10M long resistor was the hybrid divider network. I guess such a resistor network isn't required in a 0.2% meter? Could anyone point to me which ones are the alternative divider resistors? I assume they are standalone ones?
« Reply #5 on: February 12, 2025, 12:59:31 pm »
Yes, just normal (high spec) SMD resistors for the bottom dividers. Hardly any 6000 count meters will use a ceramic hybrid resistor divider. It's not woth the extra expense at that price point and resolution.
The following users thanked this post: jebem, SteveLTN
Offline thm_w
  • Non-expert
« Reply #6 on: February 12, 2025, 10:41:06 pm »
This confused me a bit too, dave had the 10M going into the ADC on the diagram for simplicity, looks like its usually switched to various discrete resistors: https://lygte-info.dk/info/DMMDesign%20UK.html
« Reply #7 on: February 13, 2025, 12:02:11 am »
Yes, as I said, it's simplified.
This is why input impedances are often 11Mohms vs 10Mohms
On a higher spec meter all the divider resistors are on the same ceramic hybrid base so they have the exact same tempco.
Offline Kleinstein
« Reply #8 on: February 13, 2025, 10:47:31 am »
There is another possible input configuration inside the DMM chip sets. This is an inverting amplifier with switching the resistor in the feedback. This curcuit is also called active divider. This way the input resistance would be constant at 10 M.
The active divider is quite common for the AC input in higher grade meters.
The following users thanked this post: EEVblog, thm_w
