Dr. Behzad Razavi has a good 1st course online, on semiconductors and devices, I haven't gotten to exotic diodes yet, or reverse breakdown in detail.
So yeah I didn't remember Schottky diodes have much higher leakage, I guess that's bad news for a low power device on a battery. I wonder what the calculus would be, for when having the lower power loss on the lower forward voltage, would cancel any long term leakage losses. Or in switch-mode circuit when it's always going forward/reverse, and you have the recovery time to worry about for reasons I can't remember.
I just measured some diode, I can't remember the # of, from a SMPS, it's not much bigger than a 1N4007, but it has a leakage I of ~150uA vs ~6-7nA for a 1N4148. Other than my lowest 10pA range is fudged up somehow, I must try measuring some op-amp and JFET gate leakage currents from my best Digikey parts.
My Electrometer uses fairly rigid triax cables, and I just made a 1st-pass at a basic test jig on a protoboard, and what a difference that makes already. No more mangled leads from the grabber hooks, or PSU clips, etc.
But I did use big pieces of female pin headers, so I suppose it will have a lot of leakage and capacitance the way I solder it together.
I need to order some proper hardware, and look up a good version to make in a big tin cookie can, w/ drilled holes and even various BNC type connectors.
Also, what textbook full of equations, would be considered the 'bible'/holybook on SMPS's and their parts ??
