The new datasheet also presents conflicting information.
6.3.1 Unity-Gain Bandwidth
The unity-gain bandwidth is the frequency up to which an amplifier with a unity gain can be operated without greatly distorting the signal. The NE5532, NE5532A, SA5532, and SA5532A devices have a 10MHz unity-gain bandwidth.
6.3.3 Slew Rate
The slew rate is the rate at which an operational amplifier can change output when there is a change on the
input. The NE5532, NE5532A, SA5532, and SA5532A devices have a 9V/ms slew rate.
Meanwhile the spec table says 12MHz and 9V/
μs. The older datasheet has the exact same chapters 6.3.1 and 6.3.3.
Also it mentions +/- 22V as potentially damaging in 7.2:
Supply voltages outside of the ±22 V range are able to permanently damage the device (see Section 5.1)
Clicking through to Section 5.1 then mentions +/-18V
This may be very nitpicking from me, but some copy-cats can get this kind of detail right:
https://www.lcsc.com/datasheet/C700139.pdfAlthough most datasheets I saw don't mention this stuff in text at all. IMHO it doesn't really present significant new information/insight. To me it feels like filler to make the datasheet longer.. but then listing specs in 2 different places is a perfect source for ambiguity..
As a designer, I'd love to see what kind of test circuit these specs were measured. Meanwhile test conditions and max specs are also removed from the datasheet. If you're building 100k+ gadgets per year, you may want to know at what kind of sigma those max specs are presented as, and how that translates into your design. Plus of course, how they are tested.
Just having a "typ" spec is kinda pointless. A lot like the uCurrent offset voltage problems I remember seeing a few years ago..
Maybe they should just started listing their dozens pages on packaging after the typical performance graphs. /S
End of rant.
As for the other parts and spec changes.. maybe an alternative explanation is because some stuff gets over-specified? Like was the original part ever that good in the first place? I don't mean this to seed conspiracy.. but there are lies, damned lies and statistics. If you measured an anomaly from spec, have you measured 10+, or 100+, or more to proof it? Some specs aren't very easy to measure, like homeopathic levels of THD or -130dB crosstalk. And then the design also needs to be correct for that to work out.
In other words: plenty of room for debate, especially if the conditions are implicit (which is why I like to see them listed in the spec tables).
