Author Topic: EEVblog #411 - MiniPro TL866 Universal Programmer Review  (Read 2049019 times)
0 Members and 116 Guests are viewing this topic.
Offline coromonadalix
Re: EEVblog #411 - MiniPro TL866 Universal Programmer Review
« Reply #2075 on: October 08, 2025, 07:15:49 pm »
for linux there was some work  to create command line tools,  some gui, and some tools for flashing, expanding the device list   etc  ...
but i don't know where they are now ...  it was mostly in githubs repos ?
but for sure  in theses programmers   linux and mac are not popular  :(
now  the only one really worthy from XGECU is the T76,  as they say  it merges the T48 and T56 functionalities ?
« Last Edit: October 08, 2025, 07:24:04 pm by coromonadalix »
Offline Quarlo Klobrigney
  • Country: pt
  • This Space For Rent
« Reply #2076 on: October 08, 2025, 07:58:59 pm »
Back to the topic, TL866CS will not detect the programmer on the USB in Linux.
The program works otherwise in Wine.
Anyone know what can help in detecting it in Wine?
Voltage does not flow, nor does voltage go.
Offline firewalker
  • Country: gr
« Reply #2077 on: October 10, 2025, 11:21:37 am »
There is a dll file you must add to the instalation directory. setupapi.dll
https://github.com/radiomanV/TL866/tree/master/wine32
Alexnader.
The following users thanked this post: Quarlo Klobrigney
  • Country: pt
« Reply #2078 on: October 10, 2025, 03:01:10 pm »
The setupapi.dll is in the path of .wine/dosdevices/c:/Program Files (x86)/MiniPro TL866 but to no avail.
Since the program should see the dll upon being invoked, I still don't see the programmer hardware.
It is seen in David Griffith's https://gitlab.com/DavidGriffith/minipro.git
terminal command line app.
I even went so far as making a bash script to do all the basics of read, write, check fuses etc.
Everything works fine in terminal.
Is there a specific place for the dll other than above, or other steps that you may have knowledge of?
« Last Edit: October 10, 2025, 03:04:48 pm by Quarlo Klobrigney »
  • Country: pt
« Reply #2079 on: October 10, 2025, 09:38:26 pm »
10,800,270 milliseconds later.......
I went about my business and Doctors appointments, and the TL866CS is recognized just fine now in the Windows software. :-//
So here to all is the progression of the programmer:
I had it working on all iterations of Windows up to 7 for many years.
I'm tired of the constant YOU MUST UPGRADE so I went the Linux route.
I got the Windows software installed for a few years on Linux using Wine.
I never tried plugging the hardware in until recently - FAIL.
Went the route of GPT and found out about the app David Griffith's https://gitlab.com/DavidGriffith/minipro.git to install using only the Linux terminal which worked fine.
With no answer, I asked here and more rabbit holes until your post firewalker https://www.eevblog.com/forum/blog/eevblog-411-minipro-tl866-universal-programmer-review/2050/?action=post;last_msg=6064603 and for Radioman's dll which in Linux took a bit to get recognized I guess.
Thank you firewalker and Radioman.
Here are a few quick commands in terminal should anyone wish to go that route to see if it indeed can connect at least.
Copy and paste any of these in terminal even with the # text after it, terminal doesn't see it.
Watch out for writing and erasing!   :o
minipro -L ATMEGA48                  # search for part in devices
or
minipro --search ATMEGA48        # search for part in devices
minipro -p 93C46 -r file.bin           # read EEPROM and save to file.bin
or
minipro -p 93C46 --read file.bin    # read EEPROM and save to file.bin
minipro -p 93C46 -b                      # blank check
or
minipro -p 93C46  --blank_check  # blank check
minipro -p 93C46 -w file.bin          # write EEPROM from file.bin
or
minipro -p 93C46 --write file.bin    # write EEPROM from file.bin
minipro -p 93C46 -m  file.bin         # verify EEPROM from file.bin
or
minipro -p 93C46 --verify file.bin   # verify EEPROM from file.bin
minipro -p 93C46 -E                      # erase EEPROM
or
minipro -p 93C46 --erase              # erase EEPROM
Read the manual in the git repo https://gitlab.com/DavidGriffith/minipro/-/blob/master/man/minipro.1?ref_type=heads for more.
Always preced the command with minipro -p <partnumber> <command> <extra>
Edited for link corrections and thanks.
« Last Edit: October 11, 2025, 07:59:44 pm by Quarlo Klobrigney »
Offline ermionesrl
« Reply #2080 on: October 17, 2025, 03:58:32 pm »
Hello.
I own a TL866A I use with minipro.
Now I need to read (and possibly write) NAND08 flash memories.
Besides the fact that an adapter is needed, the TL866A doesn't support the needed algorithm, right? NAND flashes require multiplexing of address and giving the appropriate commands.
What would you buy now? TL866II+, T48? Something else? (perhaps an open hardware, open source project?)
T56 and T76 seems expensive: my usage is very rare and probably will pass years before I will need again to do something that's not supported on simpler programmers...
Unless someone tell me they are 100% worth the price difference.
Thank you.
Offline bingo600
Offline ebastler
« Reply #2082 on: October 19, 2025, 01:40:30 pm »
Now I need to read (and possibly write) NAND08 flash memories. [...]
The TL866II plus may be an adequate and cost-effective off-the-shelf option. The current list of supported parts is here:
http://www.xgecu.com/MiniPro/TL866II_List.txt. It includes the NAND08GW3B and NAND08GW3C -- are those the specific parts you need to work with?
Offline ermionesrl
« Reply #2083 on: October 20, 2025, 09:28:47 am »
Something like this ?
https://github.com/vmallet/ftdi-nand-flash-tool
https://github.com/bkerler/NANDReader_FTDI
Yes, I saw those project and are interesting; actually I was thinking to write a kernel driver to interface the MTD layer wih FT2232 USB, so to have most already done. I was unable to find any NAND "raw" USB adapter: either they add translation, ECC, etc. in hardware, either in the driver.
But at the moment I prefer something ready made.
In my search I also found those things, that may be useful to someone:
https://www.crowdsupply.com/1bitsquared/glasgow
https://greatscottgadgets.com/greatfet/one/
Offline ermionesrl
« Reply #2084 on: October 20, 2025, 09:59:04 am »
Actually I need to read and write SmartMedia modules... seems simple, but they are not formatted with the translation layer prescribed in the standard and all current multicard SmartMedia readers, based on chip Alcor AU6348 or AU6481, when they don't see the standard translation layer, DESTROY the content on the module when you just insert it into the reader!
Thus I need to make my own reader...
Offline ermionesrl
« Reply #2085 on: October 20, 2025, 10:47:31 am »
By the way, it seems the TL866II Plus is out of production and all what I can find is counterfeit... I should buy T48 or T56 then.
I am in general strongly against counterfeit items... but in the particular case, also the original TL866 was mounting a counterfeit 3M ZIF socket... so it's a bit a controversial matter with them.
The following users thanked this post: voltsandjolts
Offline Spongey
« Reply #2086 on: October 20, 2025, 11:25:47 am »
Only T48 and T76 are receiving firmware updates.
The T76 in the longer term has much more potential due to its use of an FPGA but it is much more expensive. It isn't currently as well supported in minipro as the T48 but that will change.
So for casual use the T48 should be fine.
Offline ermionesrl
« Reply #2087 on: October 20, 2025, 01:58:40 pm »
Thanks, I just ordered the T48 on Aliexpress... they say it's 100% original, let'see.
Now I need the pinout of the adapter for NAND08 flash memories (then I will translate it to SmartMedia). I know there are ready made TQFP48 adapters, but I don't have a TQFP48 memory and buy it only to reverse engineering the pinout doesn't seem reasonable...
The thing is named ADP_F48_EX-2
« Last Edit: October 20, 2025, 02:07:26 pm by ermionesrl »
Offline ermionesrl
« Reply #2088 on: October 20, 2025, 05:07:47 pm »
...about the ADP_F48_EX-2, I just learned that those poor poor people at XGecu decided to insert a microcontroller with a sort of DRM in some of their adapters (and of course the ADP_F48_EX-2 is one of those).
IMHO It's an extremely stupid thing to add a chip with that purpose in something that electronic enthusiasts buy, and often need to use for a different function than the maker thought. By the way I already saw the cloned adapter from a vendor in Alibaba, so it got already reverse engineered (and they deserve it).
As I am somehow in a hurry I bought one of the original adapters, that costed 33% of the programmer itself. I don't know yet if the DRM check is done at firmware level, or if the windows application program does it. In the second case, as I will only use minipro, the chip is not really needed.
When I'll receive the adapter, I'll post the schematic.
Offline ermionesrl
« Reply #2089 on: November 08, 2025, 05:45:47 pm »
As promised, here is the pinout of the TSOP48 NAND adapter ADP_F48_EX-2 VER2.0:
TSOP-48 NAND adapter
C1 100nF between Vddx and Vss
C2 100nF between Vdd and Vss
Rx 68 ohm
Ry 3.9 kohm
NAND socket                programmer
    x8    x16
 4 R/^B4        ->      ->  6
 5 R/^B3        ->      ->  7
 6 R/^B2        ->      ->  8
 7 R/^B1  R/^B  ->      ->  9
 8 ^RE    ^RE   ->      -> 40
 9 ^CE1   ^CE   ->      -> 10
10 ^CE2         ->      -> 11
12 Vdd    Vdd   ->      ->  5
13 Vss    Vss   ->      ->  2, 4, 30, 38, 39 circuit ground
14 ^CE3         ->      -> 12
15 ^CE4         ->      -> 13
16 CLE    CLE   ->      -> 14
17 ALE    ALE   ->      -> 15
18 ^WE    ^WE   ->      ->  3
19 ^WP    ^WP   ->      -> 16
25        Vss   ->      -> circuit ground
26        I/O0  --> R8  ->  1
27        I/O8  --> R9  -> 19
28        I/O1  --> Rx  -> 21
29 I/O0   I/O9  --> Rx  -> 28
30 I/O1   I/O2  --> R1  -> 27
31 I/O2   I/O10 --> Rx  -> 20
32 I/O3   I/O3  --> R3  -> 26
33        I/O11 --> R11 -> 36
34              ->      -> 29
36 Vss          ->      -> circuit ground
37 Vdd    Vdd   ->      -> 31
38 PRE    PRE   ->  NC
40        I/O4  --> Rx  -> 35
41 I/O4   I/O12 --> R4  -> 25
42 I/O5   I/O5  --> R5  -> 24
43 I/O6   I/O13 --> Rx  -> 23
44 I/O7   I/O6  --> R7  -> 22
45        I/O14 --> R13 -> 34
46        I/O7  --> Rx  -> 33
47        I/O15 --> Rx  -> 32
48        Vss   ->      -> circuit ground
protection chip     programmer
8 pin (PIC?)
4  Vss   ->      -> circuit ground
5        ->      -> 18
5        --> Ry  -> 37
6        ->      -> 17
8  Vddx  ->      -> 37
Hope it's understandable and useful.
By the way, I didn't yet try to read the smartmedia with it. I was so in a hurry that I used a FT2232H board with software from here:
https://github.com/ohjeongwook/dumpflash
Code didn't work out of the box and modify python source was really painful for me as I don't really like the language, but in the end I obtained the data I needed.
Andrea
« Last Edit: November 08, 2025, 06:09:32 pm by ermionesrl »
Offline SlCKB0Y
« Reply #2090 on: January 02, 2026, 02:05:51 pm »
In your mind, what made the socket counterfeit? Did it actually include a trademark on the socket? I ask because the patents obviously expired some time back, so unless they included a trademark like “3M” or “Textool” on the socket then it’s just a legal generic version.
Offline diygescorp
  • Country: br
« Reply #2091 on: April 26, 2026, 11:46:58 pm »
Hello everybody. How's going?
I got a TL866CS (previous owner converted it to TL866A firmware) so I can program some old eproms like the 27C801 and 27C1024. Installed latest firmware and drivers, I can read code in the eproms and also do blank checks, but when I try to program a code I get the error in the print screen. This happens both for the 27C1024 and 27C801 I have here. I tried different eproms to be sure it wasn't a bad eprom, and I also selected the correct eprom and code to be programmed to each eprom. Any clues?
Edited:
I tried to measure VPP when trying to program a 27C1024, but the voltage is zero. Also, when running self test, I got a VPP overcurrent error.
« Last Edit: April 28, 2026, 02:03:21 am by diygescorp »
Offline diygescorp
  • Country: br
« Reply #2092 on: May 02, 2026, 09:55:02 pm »
Ok, solved the overcurrent issue. There was a broken inductor on the board. Replaced it, and now the self test is running ok. But I still get a similar error, and now the eprom got a couple bytes of code programmed to it (not related to the code I'm trying to program on it).
I also measured Vpp, it's set to 13.5V in the software but I'm getting 11.6V in the TL866. Could this be the issue?
Offline GarouSP
  • Country: br
« Reply #2093 on: July 01, 2026, 10:55:13 am »
Hello,
I have a TL866CS that worked perfectly for years, but now Windows 11 is blocking its driver (MiniProWdf), and I can't use it.
The "Memory integrity" option has been disabled since I bought the laptop, so I don't know what to do.
Is there an alternative driver or anything else I can do? I don't want to buy a newer programmer, as the one I have has always served me well on the few occasions I've needed to use it.
Offline retroart
  • Country: tw
« Reply #2094 on: July 07, 2026, 12:44:30 pm »
Hello,
For older devices, it is recommended to install VMware (now free) and a WinXP or Win7 operating system, followed by the necessary tools.
