Author Topic: EEVblog #933 - Keysight U1272A EMC Issue  (Read 304412 times)
0 Members and 13 Guests are viewing this topic.
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
Re: EEVblog #933 - Keysight U1272A EMC Issue
« Reply #250 on: November 22, 2016, 07:24:30 am »
HP / Agilent / Keysight didn't write which one of the Series you'll receive.
Its possible that everyone who choose the higher version, receive the 1281A.
Everything else is speculation.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #251 on: November 22, 2016, 07:27:08 am »
I do have this in writing relevant to my own submission and it will be either a U1282A or a U1281A dependent on stock availability, I specifically requested the U1282A in correspondence and offered to pay if required but that in itself is no guarantee as to what might turn up.
I understand and was told that at this point each claim will be dealt with independently until such time that a formal follow up statement is made.
Offline bernroth
« Reply #252 on: November 22, 2016, 07:34:17 am »
I do have this in writing relevant to my own submission and it will be either a U1282A or a U1281A dependent on stock availability...
This is what Keysight told me as well.
For my two meters I have chosen to upgrade one to U128xA. The other meter can be swapped in 2017 for the redesigned model.
I do still like the U1272A for its features. Its a great meter but something must have gone really wrong because of so many issues in firmware and hardware.
Offline TheAmmoniacal
  • Country: ph
« Reply #253 on: November 22, 2016, 07:42:06 am »
I'm looking forward to the redesigned U1272A, I hope they will do more than just fix the EMC issue. The slow as frig continuity buzzer on it keeps annoying me, as I don't have any faster alternatives around  |O
Offline D3f1ant
  • Doing as little as possible, but no less.
« Reply #254 on: November 22, 2016, 07:43:33 am »
If they sent me a 1281 I'd be somewhat disappointed. They really should be up front about what's being sent, if I knew I was getting a 1281 I'd opt to wait until Feb for a replacement 1272.
« Last Edit: November 22, 2016, 07:47:39 am by D3f1ant »
  • Cursed: 679 times
« Reply #255 on: November 22, 2016, 07:47:54 am »
@bernroth
I did the same, I have two U1272A meters but only made the submission for one and I'm satisfied with that, my bigger concern is that the vast majority of measurements that I have taken with these meters over many years in various environments and on a large variety of systems, equipment and devices is now questionable, I do have serious concerns.
Offline bernroth
« Reply #256 on: November 22, 2016, 08:02:42 am »
The only statistics measurements you can trust are those you falsified yourself  ;)
Offline salbayeng
« Reply #257 on: November 22, 2016, 09:01:06 am »
A bit off topic, but while testing a 160W PV booster, I had EMC issues with an ancient Priority Electronics PE-008 , it was about 1.5m from the actual booster (running at 60kHz), down by the dummy load.
 It was used for current measurement (but volts were just as bad) It would read off by a loong way (like 1/4 full scale), it was a pretty stable offset, but it changed when you moved the meter around or touched it, it was worse on the floor compared to sitting on a plastic bucket.  Still showed a reading with leads unplugged and input shorted. I have a dozen or more other meters and none were affected, even the cheap ones.
  • Cursed: 679 times
« Reply #258 on: November 22, 2016, 09:23:23 am »
Yes well, I could certainly do without a meter or two that fall within specification when regularly tested in a known clean environment but then have the potential to become erroneous and untrustworthy out in the field, pun intended.
I've posted here more information on my particular case than I ever intended but just to finish with I do get to keep the existing nominated U1272A meter and again this is documented, other peoples submissions may be different elsewhere, Keysight will notify individuals accordingly.
Offline hayatepilot
« Reply #259 on: November 22, 2016, 10:27:46 am »
+1
Especially because the U1281A lacks the 60 Ohm range, which is brilliant when tracking shorts.
Offline mtr
« Reply #260 on: November 22, 2016, 10:43:16 am »
Just talked to Keysight Germany in Böblingen, they confirmed to replace my U1272A with a redesigned U1272x.
Offline Barny
  • Country: at
« Reply #261 on: November 22, 2016, 10:45:22 am »
Replace or giving an additional DMM?
Offline mtr
« Reply #262 on: November 22, 2016, 10:57:24 am »
That is the question:-)
They were quite vague in answering this question if I have to send back my old one.
Offline bernroth
« Reply #263 on: November 22, 2016, 12:41:04 pm »
Keysight could ask you not to resell the old meter as a condition to get the replacement.
This would save cost and the environment.
You could block the amp jacks with some glue, put in in the trunk of your car and use it as emergency meter.
Just my 2 cents
  • Country: ph
« Reply #264 on: November 22, 2016, 12:54:20 pm »
If Keysight are concerned about people reselling the meters, I would be happy to give them my promise not to. Hopefully in an act of good faith they would let me keep it.
Offline bitseeker
« Reply #265 on: November 22, 2016, 10:02:37 pm »
The continuity mode on the U1250 series is slow too. However, by manually setting it to one of the Megohm ranges, continuity response is nice and fast. See if your U1272A behaves similarly.
  • Country: ph
« Reply #266 on: November 22, 2016, 10:58:53 pm »
That does help, thanks!
Offline mrnuke
« Reply #267 on: November 23, 2016, 09:01:36 am »
I absolutely love setting my 1253B for tone continuity settings and listening to it sing to me while I look for shorts.
Offline Keysight Technologies Rep
« Reply #268 on: November 29, 2016, 12:05:08 am »
Thank you for the continued discussion on electronic test and measurement, especially to the individual blogger who requested feedback on electromagnetic immunity for the Keysight hand-held digital multimeters.  Please contact us directly at this email address --  [email protected] -- so that we can better understand your measurement setup. Our goal is always to support you in your electronic test and measurement work, and continuously improve the quality of our products.  We look forward to discussing your specific situation with you directly.
Offline Brumby
« Reply #269 on: November 29, 2016, 01:13:13 am »
That's a positive indication.
If I were in Keysight's shoes and were interested in nailing down the issue, I'd be taking interest in specific cases too - for either confirmation of existing theories or adding a new dimension to the problem.
Offline eliocor
    • rhodiatoce
« Reply #270 on: November 29, 2016, 11:17:21 am »
Just received today:
Hi Elio
Thank you for your response and for choosing the option to receive a higher performance U1280 handheld digital multi-meter. We are pleased to inform that your request is being processed, and we expect to have the U1280 handheld digital multi-meter ready for shipment on 16-Dec-2016.
The shipment address will be based on the information you provided as listed below.
Your Name:                xxxx yyyyyy
Your mailing address: aaa bbbbbb cccccc, Italy
Your phone number:   +nn-nnn-nnnnnnnn
Please contact [email protected] if you have any questions.
Thank you for your support to Keysight’s products.
Thanks and regards,
Exxxxxn Cxxk
Business Process Coordinator
It seems they do not require to return the old unit!
When it will arrive I will decide what to do with the other U1272A I own: I discovered that the U1282A is a bit larger than the U1272A, so I'm not sure it will suit its carrying bag...
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #271 on: November 29, 2016, 12:56:15 pm »
I received a similar notice too.
It would be good to see a poll of how many readers have opted for an upgrade.
Anyone could set one up but it would be better on this thread?
in regards to the 1272A EMC Issue and the Keysight offer posted:
https://www.keysight.com/main/editorial.jspx?cc=US&lc=eng&ckey=2806392&id=2806392
Choose One:
  • Have contact Keysight to receive a higher performance U1280 series handheld digital multimeter
  • Have contact Keysight to receive a redesigned U1270 series handheld digital multimeter available in February, 2017
  • Will keep what I have and do nothing
  • I am reading this thread but do not own the affected DMMs
Best Wishes,
 Saturation
Offline Tom45
« Reply #272 on: November 29, 2016, 04:12:38 pm »
I haven't heard anything further from Keysight but since I chose the upgraded model not due until February there probably isn't any news to be had until we get closer to February.
  • Country: ph
« Reply #273 on: November 29, 2016, 04:46:02 pm »
I requested a U1280-series, the 16th this month. Said they would come back to me in 2 weeks, which would be tomorrow. We'll see!
Offline saturation
    • NIST
Best Wishes,
 Saturation
The following users thanked this post: Muttley Snickers
