Author Topic: EEVblog #951 - Mailbag  (Read 16150 times)
Offline boffinTopic starter
« on: December 06, 2016, 05:12:11 am »
  • A watch made from a old IBM Microdrive Hard Drive Drive! http://hddwatches.com/
  • Tearing down and debunking a Hyper Voltage Stabiliser car energy smoothing bullshit device.
  • Panduino Uno compatible Arduino
  • Dell Server destroyed by super Neodymium magnet! Brainiac75 Youtube
  • My Playhouse Youtube:
  • Hardware Hacker book by Bunnie Huang https://www.nostarch.com/hardwarehacker
  • BMW 5 series keyfob receiver teardown
  • ESD Wriststrap teardown
  • CCCP Ohmeter
  • Wun Hung Lo brand GoPro/SJCAM ripoff camera tested
  • Dodgy battery charger
  • 4 banger calculator
And, if you start pinning out the missing chip on that battery stabilizer, you'll find it's a 555 timer, to make the LED blink. Obviously that's the for the enhanced "Turbo Hyper Voltage Stabilizer"
« Last Edit: December 06, 2016, 06:11:54 am by boffin »
The following users thanked this post: jonovid
Offline MK14
Re: EEVblog #951 - Mailbag
« Reply #1 on: December 06, 2016, 05:14:42 am »
Offline EEVblog
« Reply #2 on: December 06, 2016, 06:08:00 am »
Dave, if you start pinning out the missing chip on that battery stabilizer, you'll find it's a 555 timer, to make the LED blink. Obviously that's the for the enhanced "Turbo Hyper Voltage Stabilizer"
LOL!
« Reply #3 on: December 06, 2016, 06:12:41 am »
LOL!
about 50% @ 0.6Hz if my math is right for the 470k / 18k / 2u2
Offline TheAmmoniacal
  • Country: ph
« Reply #4 on: December 06, 2016, 06:36:46 am »
I couldn't tell if the HDDWatch works as a watch, or if it's just for show. Do the minute/hour hands move at all?
Offline bktemp
« Reply #5 on: December 06, 2016, 07:20:55 am »
At 44:12 while showing the 4 pin hall sensor on the fan pcb to the camera: "...there is no hall sensor..."  :-DD
If the schematic in the motor driver datasheet matches the circuit on the fan, I don't think an overvoltage generated by the coil windings could destroy the controller ic: There are external mosfets and the feedback is done using a hall sensor, so there is no direct connection between coils and ic. The only thing I can imagine happening is destroying the mosfets.
Offline EEVblog
« Reply #6 on: December 06, 2016, 07:41:32 am »
LOL, yeah, missed that.
Offline Someone
    • send complaints here
« Reply #7 on: December 06, 2016, 08:30:18 am »
From a strong external magnetic field its likely saturation/magnetisation of the "permanent" magnets and/or the field laminations. Not electrical stress, with a small outlier chance of magnetisation of the hall sensor so it will no longer start.
Offline jonovid
    • JONOVID
« Reply #8 on: December 06, 2016, 09:13:43 am »
like the watch.  :-+    but the disc should move or something.  maybe add a second hand from the drive arm swinging on its post?
Neodymium magnets also do wonderful things to pub poker machines. just be sure to exit the room for before thay figure out who
tripped off a security network shutdown of all machines.
« Last Edit: December 06, 2016, 11:13:35 am by jonovid »
Hobbyist with a basic knowledge of electronics
Offline Barny
  • Country: at
  • I'm from Austria, not Australia ;)
« Reply #9 on: December 06, 2016, 10:19:34 am »
Clive had a go with an fan of this server:
The mail bag video had some strange cuts & some strange audio (not the crap-camera section)
« Last Edit: December 06, 2016, 10:23:09 am by Barny »
Offline testian
« Reply #10 on: December 06, 2016, 05:06:27 pm »
Just watched the new video and also noticed that.
But do you think, like Dave, the "The Hardware Hacker: Adventures in Making and Breaking Hardware" book is worth a read? Sounds very interesting but unfortunately I cant find a preview of the book.
Offline Carl_Smith
    • MegaMicroWatt - Carl Smith's Blog
« Reply #11 on: December 06, 2016, 06:47:19 pm »
Don Hoover, your entry for the worlds most dodgey battery charger contest is rejected.  Way too many parts.  :)
I have several Black and Decker screwdrivers that use the cylindrical "VersaPak" batteries.  The charger is nothing but a transformer, one resistor, and the "charging" LED.  That's it.  They use the charging indicator LED as the rectifier and just cook the battery with half wave rectified AC.  The batteries will be damaged the first time you forget them in the charger for more than 8 to 10 hours.
I've bought new batteries and remembered to only put them in the charger for 8 to 10 hours and then remove them, and they lasted fine for a year or two, then I forget them in the charger for a few days and after that their capacity is greatly reduced and they don't hold a charge for more than a few days because of the damage by overcharging.
Also, I have a cheap battery powered toothbrush with an inductive charging base. I took the brush apart once just out of curiosity and the charging circuit in the brush is just a coil, diode, and battery. If you leave it in the base all the time it is always warm. I realized right when I got it, long before taking it apart, that it wasn't doing proper charge control. The warmth is due to the battery being overcharged. So I only plug the charger base in when the brush actually starts noticeably slowing down, and then I only leave the charger plugged in over one night. The thing is, I can use it twice a day for probably two weeks before it needs to be charged again. So that means when most people just leave the charger base plugged in, it's cooking the battery most of the time. It only really needs about 8 hours on charge once every two weeks.
As much as I usually hate the government meddling with things, I've seen so many of these dumb charger circuits that I think they should make a law that requires proper charger circuits that don't kill batteries.
Offline bktemp
« Reply #12 on: December 06, 2016, 07:05:13 pm »
Yes, if you want to see really dodgy ones, look at Big Clive's Youtube channel. How about charging a 3.6V lithium battery using 12V + a resistor?
Offline Carl_Smith
« Reply #13 on: December 07, 2016, 01:49:04 am »
Ouch.  At least the bad NiCd/NiMH chargers probably won't set your batteries on fire.
I watch Big Clive but he posts so much stuff I can't keep up with all of it.
Offline Luminax
  • Country: my
    • Electronesk
« Reply #14 on: December 07, 2016, 03:14:07 am »
My brother used to work in an auto parts shop that does peddle those stabilizer thingie... I think one of them was labelled "Ultimate bateri turbo stabilizer" or some other dumb BS... got my bro to nick a few of them for the aluminium casing.
They make for a rocking small amplifier case!
Jack of all trade - Master of some... I hope...
Offline Brumby
« Reply #15 on: December 07, 2016, 05:18:24 am »
I was thinking the case had some appeal as well.
You have to wonder, though, why the PCB?  Perhaps it was just for show if someone did open it up.
I was on board with Dave's capacitor prediction from the word go, but I really cracked up when he started reading out the 'features'... From the "Yeah, okay" to the "Huh?" to the ROFLMAO.
Oh man ...... If I had no scruples, I could be a millionaire.
Offline Luminax
  • Country: my
    • Electronesk
« Reply #16 on: December 08, 2016, 01:28:41 am »
Those features were....  :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD :-DD
Followed with  |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O |O
And some  :scared: :scared: :scared: :scared: :scared: :scared: :scared: :scared:
Sorry for the flood
Offline EEVblog
« Reply #17 on: December 08, 2016, 03:28:03 am »
I just switched to Sony Vegas 14 and have had some rendering issues so maybe that's it?
Offline EEVblog
« Reply #18 on: December 08, 2016, 03:30:17 am »
I've seen that too. I thought it would just be a dropper, was surprised by the complexity in this one  ;D
Offline bitwelder
« Reply #19 on: December 10, 2016, 02:30:41 pm »
It seems Dave has completely missed/skipped to show the iSesame spudger (around 7:35).
As I've seen briefly that tool already in Big Clive's hands, it would been nice to hear what's Dave opinion on it.
Offline Kleinstein
« Reply #20 on: December 10, 2016, 04:31:45 pm »
The more detailed tear-down from clive's video gives a few more clues to why the fan might have failed.  Looks like damage done from to much current / voltage. It could be an indirect damage:
The magnet could influence the power supply to give more than 12 V to the fans (and hard drives) and this could very well blow zeners in that position. Some power supplies use transductors to regulate some of the output voltages and these are known to be sensitive to a strong magnetic field. Still a little surprising it is enought to blow the zeners.
Offline guido
« Reply #21 on: December 14, 2016, 12:01:04 am »
The EA logo is Electronic Arrays.
I have an IC lying around (EA2022 1979), but i could never find any info on it.
It's in a box with other unknown silicon objects.
