Author Topic: EEVblog #978 - Keysight 1000X Hacking  (Read 432313 times)
Offline mrpackethead
  • D Size Cell
Re: EEVblog #978 - Keysight 1000X Hacking
« Reply #150 on: March 12, 2017, 07:51:52 am »
IANAL.  The Keysight legal department would be the people to ask.
I doubt you would get an unbiased view from Keysights legal department!
The following users thanked this post: Sigurd
Offline Brumby
« Reply #151 on: March 12, 2017, 07:59:01 am »
Why would you need an unbiased view?
I would have thought their view would be EXACTLY the view that would be of interest.
  • D Size Cell
« Reply #152 on: March 12, 2017, 08:21:27 am »
Because their view will be tainted by the fact they want you to belive that they have all the power.
What i want to know is what law would be broken, by swapping some resistors and reselling something you own.
Again i repeat i'm not at all interested in doing this.  Its not worth the drama but it is interesting
Now back to our normal programming.
Offline JuKu
    • LitePlacer - The Low Cost DIY Pick and Place Machine
« Reply #153 on: March 12, 2017, 08:52:36 am »
I'm not a lawyer, but I like to theorize. I don't think you'll break a law, but you might break a license or publish trade secrets. Now, if the resistor values are generally known, like published on an Internet forum, I think you could sell an "original" scope and offer to do the modifications for the buyer. Once. If you start making money doing that, then a whole lot of other laws ( country dependent, of course) about what are  acceptable business practices come to play. I'd guess you'd lose that.
I wouldn't do that either, but I might buy a Keysight, if my trusty HP ever dies.
http://www.liteplacer.com - The Low Cost DIY Pick and Place Machine
Offline Fungus
« Reply #154 on: March 12, 2017, 09:59:29 am »
I am tempted to buy one of the DSOX 1000 scope just to get the Bode plot function.
Have you seen the bode plot?
https://www.eevblog.com/forum/testgear/new-keysight-scope-1st-march-2017/msg1153443/#msg1153443
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #155 on: March 12, 2017, 10:06:57 am »
You can only break a license if you have agreed to it. There is an EULA in the box but unless you admit to have read it, it's highly unlikely to be enforceable.
That is only an issue if you publish "inside" information, e.g. if you are an employee or came by info under NDA.
Day Job: Mostly LEDs
« Reply #156 on: March 12, 2017, 10:08:49 am »
Wait & see if they will improve the resolution. in its present form it's near-useless.
You can do frequency response plots using the wavegen ( FM modulation with ramp ,100%  symmetry, trigger from wavegen modulation)
Offline Fungus
« Reply #157 on: March 12, 2017, 10:12:23 am »
So given where this is going would you even bother going and buying a Rigol now?
The Fat Lady hasn't sung yet, and:
* Rigol hacking doesn't require taking it apart and soldering microscopic resistors. A lot of people aren't up for that
* Software hacking this hasn't even started yet and might prove difficult (eg. take it apart and use a JTAG programmer)
* It still costs 50% more than a Rigol and has less features (eg. less channels, less memory, no Ethernet)
But ... if an easy software hack appears for this it would be a very attractive option, yes.
Offline ebastler
« Reply #158 on: March 12, 2017, 10:26:11 am »
Well, even so, "just" with the already-confirmed(?) hacks, you can turn a 600$-ish 50MHz educational-wavegen one into a 1000$-ish >200MHz fully-fledged one... Which isn't too shabby in itself, imho.
Hang on, have I missed something? Has anyone confirmed that the resistor hack works using the 50MHz EDUX version as the starting point??
« Reply #159 on: March 12, 2017, 10:40:56 am »
No.
Bear in mind it's possible there are hardware differences in the front end, as there isn't an official upgrade path for that model.
« Last Edit: March 12, 2017, 10:42:33 am by mikeselectricstuff »
The following users thanked this post: ebastler
Offline EEVblogTopic starter
« Reply #160 on: March 12, 2017, 10:51:25 am »
No law has been broken unless that's what a judge rules at the end of a court case.
The problem with cases like this are:
a) They are so rare that there is very little existing case law
b) Cases are always different and highly reliant upon technical detail an interpretation of existing laws that almost never cover that exact circumstance
c) They can be very often international in nature which complicates things enormously
d) They are very extensive and costly, and because they often have a broad reaching public interest nature, often go to the highest court in the land. They often become landmark trials so to speak if defended far enough.
Offline bitwelder
« Reply #161 on: March 12, 2017, 11:05:22 am »
There are several other new scopes coming it seems, so waiting a little might make sense. Also the 1000X series doesn't have the software licenses hacked and I doubt that will happen anytime soon. For many people the DS1054Z may still be tough to beat - unless they prefer to see a higher end brand name on the bench(and who doesn't?).
And also, the Rigol is a full 4-channel scope, while the 1000X is... less than 3?
« Reply #162 on: March 12, 2017, 11:08:47 am »
I will have my hands on a new budget 2CH scope on Wed.
It's kinda weird in that there doesn't seem to be any date embargo with it, and the exchange will take place with trenchcoats outside the dumpster room at midnight.
The following users thanked this post: thm_w, Relaxe
Offline Brumby
« Reply #163 on: March 12, 2017, 12:04:18 pm »
Intriguing.    8)
Offline Fungus
« Reply #164 on: March 12, 2017, 12:50:42 pm »
Wait a couple of weeks and see where this hacking goes. Be aware that the Keysight costs 50% more, has less features, and resistor hacking will almost certainly void the warranty. Even if you restore the original resistors it will probably be obvious that they're hand soldered.
(Rigol hacks can be removed in seconds with telnet and an Ethernet cable).
« Reply #165 on: March 12, 2017, 12:56:58 pm »
Piggyback resistor with z-axis tape perhaps.
Offline firewalker
  • Country: gr
« Reply #166 on: March 12, 2017, 02:00:53 pm »
I don;t believe it is illegal to resale "improved" hardware, if you don't sale the way to mod it. If that was the case a chip tuned car would be impossible to sale.
Alexander.
« Reply #167 on: March 12, 2017, 03:19:45 pm »
Poking around the front end, it appears the bandwidth is limited in the ADC/ASIC.
In 5V/div & up ranges it's actually good to about 350MHz.
The following users thanked this post: KhronX
« Reply #168 on: March 12, 2017, 05:01:26 pm »
Most useful I found for an 1102G is 03, which gives 200MHz and 2GSps.
config 03 appears to have some subtle issues - CH2 edge trigger stops working when serial bus is enabled.
« Last Edit: March 14, 2017, 02:17:00 pm by mikeselectricstuff »
Offline Domagoj T
  • Country: hr
« Reply #169 on: March 12, 2017, 05:34:41 pm »
Now? Well, there may be a dilemma, but two years ago when I wanted a scope, DS1054Z was all the rage. I bought it because it has 4 channels (2 is nice, but 4 is more), hackable and affordable (or at least, within my purchasing power; I was asked by family members "How much did it cost? Do you really need that? What is it, anyway?" "A lot. No. An oscilloscope.").
If I was buying a scope today, perhaps I would choose some other brand and model, but two years ago, it was a good deal. Now I have a scope and honestly don't see a need for another one. This one is perfectly fine.
At this moment, even if Keysight was the same price as this Rigol, and had better features, I still wouldn't buy it for one simple reason - I already have a scope. Keysight was late to the party. I suspect I am not the only amateur hobbyist tinkerer that made the same decision.
Offline fullyBoricua
  • Country: pr
« Reply #170 on: March 12, 2017, 06:35:06 pm »
EDU models come with 75Mhz probes... Highly unlikely EDU models will get to 200Mhz as the DSOXs.
Hope to be wrong though!
  • D Size Cell
« Reply #171 on: March 12, 2017, 06:56:07 pm »
Is it ethical.. well thats a different discussion..
« Reply #172 on: March 13, 2017, 12:39:26 am »
The one mentioned here?
https://www.eevblog.com/forum/testgear/scope-wait-for-new-models/msg1090385/#msg1090385
Avid Rabid Hobbyist
Offline Bud
« Reply #173 on: March 13, 2017, 02:16:18 am »
Well, this was not hard to predict
The ethics police will be here soon with their stock moral bankruptcy thing.
  • D Size Cell
« Reply #174 on: March 13, 2017, 03:16:45 am »
Lets not have the ethics discussion here.. you can have it over there ---->
