Author Topic: (AUS) Vacuum Fluorescent Display s 11-digit at Jaycar for $2.95  (Read 2399 times)
Offline austfoxTopic starter
I spotted these at my local Jaycar this morning for only $2.95 each, so grabbed a few. They are probably cheaper direct from China, but not a bad price for a retail store.
Haven't seen VFDs for sale since the late 90's... now I just have to figure out what I should build to make use of them...
Offline wilfred
Re: (AUS) Vacuum Fluorescent Display s 11-digit at Jaycar for $2.95
« Reply #1 on: May 18, 2023, 08:14:25 am »
Does the leaflet recommend a suitable driver chip? Does Jaycar sell it?
Offline retiredfeline
« Reply #2 on: May 18, 2023, 08:19:42 am »
Wow, must grab. Which shop was this? Might be a manager special.  :(
Offline Brumby
« Last Edit: May 18, 2023, 08:43:51 am by Brumby »
The following users thanked this post: retiredfeline
« Reply #4 on: May 18, 2023, 08:52:16 am »
Ah, should have known they would abbreviate fluorescent to fluoro.
« Reply #5 on: May 18, 2023, 08:58:15 am »
OT News for the Melbourne mob too Rockby is relocating to Rowville from Clayton
VFD driver IC's worth checking the datasheets btw https://www.rockby.com.au/CatresultsSql_12.cfm?Searchkey=display+driver&stock_no=22511
The following users thanked this post: leighcorrigall
Offline johnboxall
  • You do nothing, you get nothing.
    • Books, services and more:
« Reply #6 on: May 18, 2023, 10:18:14 am »
ZD1882
UDN6118A
https://www.jaycar.com.au/udn6118a-driver-to-suit-fluro-display-dip18/p/ZD1882
« Reply #7 on: May 19, 2023, 01:24:38 am »
Looking at the datasheet supplied by Jaycar which is the same as others on the Internet, the VFD is a Futuba 11-ST26A, and that will get you a bit more information, including posts by people who have used it. The Moddate attribute of the PDF is 2006-04-05 so the display is at least that old.
The segment and grid voltages are given as 12V so it's possible to drive them with 4000 CMOS gates, but one poster said it was a bit dim and used 20V.
The following users thanked this post: austfox, I wanted a rude username
« Reply #8 on: May 19, 2023, 01:38:33 am »
ZD1882
UDN6118A
It looks like the UDN6118 is 8 x darlington transistors, so I am not sure what the difference between it and the cheaper ULN2003 is?
Thanks to retiredfeline I will have a look at other users to see the best option on how to drive them.
« Reply #9 on: May 19, 2023, 04:07:03 am »
Jaycar I went to didn't have stock, despite what their web site said. Will try other stores next week.
« Reply #10 on: May 19, 2023, 04:13:35 am »
No, look at the internal schematic. The darlingons are high side.
Offline wilfred
(AU) Jaycar sale solder (60/40) 1000g 0.71mm & 1.0mm AU$69
« Reply #11 on: May 28, 2023, 08:21:37 am »
I notice Jaycar have a sale on and solder is reduced.
https://www.jaycar.com.au/0-71mm-duratech-solder-1kg/p/NS3002?pos=4&queryId=88168642201ecf1d18b7a089bb868ed3
https://www.jaycar.com.au/1mm-duratech-solder-1kg/p/NS3015
The Jaycar website says they are discontinued and the 1kg 0.71mm roll is 500g, 1000g pictured. I bought a roll and it is 1000g. The website points to the replacement stock which is 500g for a dollar more. 200g rolls are $25.
Online Someone
    • send complaints here
Re: (AU) Jaycar sale solder (60/40) 1000g 0.71mm & 1.0mm AU$69
« Reply #12 on: May 28, 2023, 10:28:43 am »
Shop around, you can get brand name eutectic rosin core (say Multicore 362) for less.
The following users thanked this post: Ed.Kloonk
Offline 5U4GB
« Reply #13 on: May 28, 2023, 11:24:20 am »
Here it is: https://www.jaycar.com.au/11-digit-fluoro-display-bargain/p/ZD1880?pos=9&queryId=c99746bdd37680867e0544f1658636d6&sort=relevance&searchText=display
Also available in Noo Zild for an equivalent price, so it seems to be company-wide.
The display also features an apostrophe in the top right hand corner of the digits, and a semicolon ; in the bottom in all 11 digits.
I don't know of any country that uses a semicolon as a digits separator so I'm guessing it's a switchable comma vs. period rather than a semicolon.  The cut-off-halfway data sheet mentions a "lower comma" and "decimal point" but no "upper comma", does someone who's got one want to try lighting it up to see which is which?
« Last Edit: May 28, 2023, 11:30:15 am by 5U4GB »
Offline wilfred
« Reply #14 on: May 28, 2023, 11:52:06 am »
Well how about a link. Even in Melbourne I don't know of many places that sell solder. I doubt I'll need solder for quite a while now. But I'd still like to know how much effort I needed to go to, to get a better value.
I expected to get a response advising of better value. I just leave it to others to make their own choice.
Offline nctnico
« Reply #15 on: May 29, 2023, 04:14:16 pm »
I bought a couple of such displays in the 90's... Still don't know what to do with them and I likely threw them out a while ago. My advice: only buy parts you need for a current project otherwise you end up with a hoard of unused parts like me.
The following users thanked this post: thm_w, I wanted a rude username
Offline OZ1LQB
« Reply #16 on: May 29, 2023, 04:57:44 pm »
nctnico..
is that a bad thing ;-)
Offline Brumby
« Reply #17 on: May 30, 2023, 05:58:36 am »
(It depends who's asking  ;D )
« Reply #18 on: May 30, 2023, 06:24:35 am »
SHMBO to Brumby what did you buy 'this time'   :-DD
When you reach the point of not wanting to or being able play with fun toys then is life worth living? Lots to be learned playing with new or offbeat stuff and for very few $ in this case.
Offline Brumby
« Reply #19 on: May 30, 2023, 11:04:28 am »
NERF Super Soaker XP100 Water Blaster (at the request of the wife).
We have some sulphur crested cockatoos taking an unhealthy interest in our house and need some discouragement.
As for other purchases, I've had to wind back on that until I can make room to:
 1. Organise garage and other areas so that I can:
 2. Store what I have in an accessible manner
and
 3. Work on/utilise existing acquisitions.
Current plans and budget are directed towards storage products.  *sigh*
Offline nctnico
« Reply #20 on: May 30, 2023, 02:33:24 pm »
Everybody is bound to the amount of time they are alive. So only buy the toys you have time for to play with... I'm quite sure that when I die at high age I still have a TODO list long enough to last another lifetime and probably even longer.
The following users thanked this post: OZ1LQB, PA0PBZ, Brumby
« Reply #21 on: June 02, 2023, 03:46:53 am »
Quote from: nctnico
Yes but there no way of knowing how much time that is. :-DD
