I have quite the collection of Z0 resistive probes. I've no idea why I've been collecting them, but now it's time to divest myself of them.
It's too bad I only now, while googling to write this ad, learned of the AKL-PT1 DIY probe.
https://hackaday.com/2020/05/07/open-source-2-ghz-oscilloscope-probe/https://www.kickstarter.com/projects/azonenberg/akl-pt1-2-ghz-passive-oscilloscope-probe/descriptionhttps://github.com/azonenberg/starshipraider/tree/master/boards/probes/handheld-resistive-probeLooks like he had 100 PCBs made for 25 backers. Who knows if he made all 100 PCBs into probes though. The store they sell through (Elegant Invention) is shut. So either way, it looks like you can't buy this now. At $250, I'm not entirely sure they are worth it. You can get a 10020A set for less than that. So had I known about it in advance perhaps I would have passed regardless.
Enough! You know what a resistive probe is. I
think I have every commercially made one. I am nearly certain I have enough qty to satisfy demand. These things just aren't in demand. Most people that can afford a high bandwidth scope can probably afford an active FET probe, which is more versatile.
Higher offers will get the better quality / more complete kits. PM me and let me know what model you want and an offer price. I'll collect offers for a bit then send them out all at once. Paypal or Apple Pay are accepted. Cash as well, if you don't mind sending it through the mail. I can do international shipping if you want to pay the ebay global fees on top, otherwise USA only.
I won't post the pictures here, because the sets are in different states of accessory contents. You can find representative pictures online. I will send you the pictures of the actual set you are buying for your approval before completing the sale. Most of my sets are in quite good condition, and quite complete. I will mix and match accessories to build complete sets in the highly likely case that the sales aren't fully subscribed.
You can find current asking prices on ebay and offer much lower than that. Those sets literally never sell at those prices. The $250 for 2GHz (900fF) for a DIY set with a very long rigid probe body, vs $??? for a used commercial 6+GHz (100fF) set with very small "operating area" (basically just a probe tip immediately terminating into a cable), vs current ebay asking prices, should give you a guide on what to offer.
I've attached the user manuals for the various kits to this post. Below are the list prices when new. I think the Lecroy is the only one still sold new.
Each kit has its own unique advantages and disadvantages in their use. Besides the obvious performance difference, there are ergonomic differences. Not bad or good, they are just all different from each other. Unlike your standard passive probe, which are all alike.
HP 10020A ($100 in 1978 dollars == $746.89 in 2020 dollars). This is a fun probe because it contains many ratios, including 1:1. But the performance is the worst -- they aren't even rated! Tip capacitance is 700fF, so you do the math. per HP,
"Effect on risetime of a 100-MHz system is negligible". The probe tips screw on to the handle and contain the resistor. The tips have a .25"-ish dia metal body, stainless I think. I had one set that was moderately corroded, a bunch of normal use looking sets, and then later I got a set that looked absolutely brand new. It inspired me to polish the grime off of the worst set. It came out sparkling and while I don't have a 2GHz scope to test the performance, it seems ok after the procedure. Anyway, these are made in the old fashioned way, to last. I have very many of these, so I suggest "ordering" 2 sets ...
Otherwise the price will be so cheap as to hardly be worth my while.
Tektronix P6150 ($1860). Interesting ground clips for these. Also these are the most interesting probe tips as there is a PCB adapter (I have many) that you solder on as a test point. It holds the probe tip rigidly. None of the others have that feature or even capability, so for the others you have to setup a separate fixture for non-momentary probing, like you might do for any modern passive probe.
HP/Agilent 54006A ($3400). These are built around a specific Caddock resistor, made just for Agilent. I have a lot of these, but also many missing parts. You never see these for sale with a full complement of resistors. At one point the connector design changed. The new style is more attractive to look at but I doubt there's any performance difference -- seeing as how the model# didn't change. Probably a supplier change (old connector no longer available) as opposed to an intentional design change. Some of these are branded HP and some Agilent. There's not a consistent change in apparent quality or age across the 2 different brandings. Also I may have mixed the parts up across sets anyway. But if you want a case that is branded one way or the other, specify that.
Lecroy PP066 ($1600). This one is rated to the highest frequency, 7.5GHz. It's the same design as the 54006A physically, but with
a different resistor -- HDK apparently. I've attached a photo of them because you won't find it online. As well, it's very beautifully made. The package is some kind of epoxy. The back side is symmetrical to the front, ie the main body is flat. It suggests a stripline, although I don't see how that can be the case. The photo gridlines are 5mm square. I only have one of these sets, and I would want a lot to part with it.
If you even got through this post, expect to wait some time for me to collect all the orders (if any!) before I fulfill them. I want to get rid of these, not maintain a museum, so offer accordingly.
