I have a Prema 5017 SC for sale. The unit was last serviced and calibrated on 27.09.2018 at Prema by the hands of Mr. Stricker before he retired. All electrolytic caps have previously been replaced by high quality Nichicon. It's in excellent cosmetic condition and has the latest updates and upgrades installed and works perfectly.
Advantages:
- illuminated LCD display --> no fading like VFDs
- it uses standard components --> in case easy to repair
- no sheet metal case, but massive aluminium corpus --> no corrosion
- no fan inside --> silent operation
Description: PREMA 5017 SC, 7 1/2 digit multimeter
https://www.prema.com/index.php/de/service/messgeraetewartung/item/download/187_101811f6c67bdbc737426db4f03374f4- functions: Vdc, Vac, Idc, Iac, R, T, f, ...
- high resolution: 10nV, 10µOhm, 100pA, 0,001ºC
- stability: 24-hour 4ppm, 1-year 20ppm
- math functions: offset, %-deviation, ratio, ax+b
- display format: ±30.100.000 (plus an extra digit when using math function by hiding leading zeros)
- measurement period: 20ms ... 100s
- temperature measurement with Pt10, Pt25, Pt100, Pt500, Pt1000
- interfaces: IEEE488 and RS232
- build in multiplexer/scanner with 80x channels common ground / 40x channels 2W / 20x channel 4W
I'm asking for 800€ + shipping. The unit can be checked and picked up personally if you like. International shipping is no problem.
-branadic-
