https://www.ebay.com/usr/wallyb110Check it out :-)
Heres the one deal that I have only found at two different site, their prices were $100-100 for a new battery.
Geekaroo I.T. LLC :
(We specialize in Apple Newton eMate 300's)
This battery replacment mod we do is to help keep alive the emate 300's and raise money for our company to continue to buy, repair and share them for years to come.
Apple Newton eMate 300 Battery replacement. Shipped with USPS Priority Mail.
If your eMate 300 is like most, with age the battery no longer holds much of a charge (if it holds any at all).
Mail Geekaroo I.T. LLC your eMATE 300 battery and we will repair or replace the battery pack with brand new cells.
After making the purchase follow these easy instructions.
Instructions: (Follow pictures)
1) On the bottom of your eMate there are two screws towards the handle, these hold a plate in place.
2) Using a T-8 bit unscrew these two screws. (Becareful to not lose these screws).
3) Remove the plate and under it you will see the battery pack.
4) Unplug (gently) the battery pack and place it aside.
5) Now put the plate back on and put the screws back in place tightly.
(We will email or msg you the address to send the battery or emate unit itself)
You can still use the eMate with the charger while you wait for your new battery pack to arrive.
Please allow 5-7 business days of receiving your battery pack for us to ship replacement.
Each of the 4 new Cells will be 1.2v 2300mah. (If you would like batteries higher than 2300mah, please contact us.)
The original eMate 300 cells were 1.2v 1200mah. So you will be almost doubling the battery life with the new pack from us.
Average battery life: 38+ hours (w/backlight off).
Average battery life: 18+ hours (w/back light on).
We ship each new battery pack with instructions on how to reinstall the pack and get ya back up and running. (with pictures).
Each new pack will be charged and burned in for 72 hours before being shipped.
* Please make sure the AC Adaptor you are using is the original (Apple item #H0232) some 3rd party adaptors can cause damage.
(Original specs for the original charger is 9W 7.5v 1.2 amp.)
We also provide additional services for eMate 300's please message us for more info. :-)
But we sell tons of other stuff. Unlisted is a ton of 72pin ram and some laptop ram. Next up is some vintage HD's i rarely used, going to test them and format them and they will be up on ebay.
Thanks
-Walt
