Author Topic: EBAY FS (Germany) : Medical Isolation transformers, 230V, 150VA, 54EUR  (Read 10659 times)
Offline FalkraTopic starter
Hello,
I recently bought two of these isolation transformers from this ebay seller (nitram39).
Theye were like new, with original packaging, and shipped quickly.
I posted the link in the latest purchase topic, and another forum member bought one.
Here is the link : http://www.ebay.fr/itm/322215543868
The seller already has sold 3, and his ebay sales are for two at a time.
When two isolation transformers are sold, he sells 2 more, later, so the link changes but you can find them from the user name.
3 attached pictures.
Just for sharing, if anyone is interested. These are not my auctions/sales.
54 Eur seems to be a good price (IMO), shipping was 12EUR (to Europe).
« Last Edit: August 04, 2016, 10:16:27 am by Falkra »
The following users thanked this post: neslekkim
Offline neslekkim
  • Country: no
Re: EBAY FS (Germany) : Medical Isolation transformers, 230V, 150VA, 54EUR
« Reply #1 on: August 04, 2016, 11:33:12 am »
Oh.. hope he can ship to Norway also.. have asked so hopefully they aren't sold before I get an answer :)
« Reply #2 on: August 04, 2016, 12:31:00 pm »
I hope you can get it.
The seller didn't answer instantly but I got a good contact with him (in english... my german is very bad).  ;D
Good luck, don't hesitate  to post your feedback when you get the transormer, if everything is ok.
« Reply #3 on: August 04, 2016, 03:22:30 pm »
I see both have been sold. I'll update the link in the first post if the seller has more.
Offline neslekkim
  • Country: no
« Reply #4 on: August 04, 2016, 06:44:57 pm »
Hope they will work as expected
« Reply #5 on: August 04, 2016, 07:24:10 pm »
I hope so.  ;D
Mine were ok, like new.
Online PA0PBZ
« Reply #6 on: August 07, 2016, 05:04:40 pm »
I messaged the seller and found that he does not have more of these, so if anyone thinks one is enough I'd like to buy the other one  ;)
Offline Iwanushka
  • Country: lt
« Reply #7 on: August 07, 2016, 06:48:48 pm »
Looking for one too!
When all you've got is a hammer, everything starts looking like a nail.- Attrition.
Offline HighVoltage
« Reply #8 on: August 07, 2016, 09:03:57 pm »
What is so special about a "medical' insulation transformer?
Just better quality and higher reliable transformer?
Offline electr_peter
  • Country: lt
« Reply #9 on: August 07, 2016, 09:38:53 pm »
Nothing too special - mostly quality and piece of mind. These medical tranformers in particular:
  • have low leakage current (both input and output)
  • have multiple protection from over-current/over-temperature
  • are insulation tested to 4kV AC RMS
  • have shielding between input/output windings
In other words, having this thing in one's lab should not increase risk of fire.
Before usage as true isolation transformer, be aware of actual wiring inside:
  • Input live/neutral is isolated from output live/neutral (obviously)
  • Input/output earth is not connected to any winding (check to be sure, some medical transformers have output neutral and earth connected).
  • Input earth is carried through to output earth (!!!) - one may have to take this into account in some situations or make modifications as needed. Having carried through earth may compromise "isolation" in some measurement situations.
« Last Edit: August 07, 2016, 10:53:00 pm by electr_peter »
Offline neslekkim
  • Country: no
« Reply #10 on: August 07, 2016, 09:59:08 pm »
Are you saying that this one have earth carried throuhg?, or that one in general should check that on such transformers?
For me the issue is the earth, want to use it on the occasions where I don't want to blow up the scope :)
Medical or not, that was not so big issue, the point was to finally get one that would isolate 230v - 230v..
Online Monkeh
« Reply #11 on: August 07, 2016, 10:19:32 pm »
If there is no earthed wire there is no neutral.
Offline TopLoser
« Reply #12 on: August 07, 2016, 10:51:07 pm »
"Output floating, Neutral not grounded"
From pics on the first post.
Online Monkeh
« Reply #13 on: August 07, 2016, 10:53:41 pm »
Sadly even the manufacturers can't get simple terminology correct.
Online nctnico
« Reply #14 on: August 07, 2016, 10:54:19 pm »
The usage for a isolation transformer in medical equipment is (probably) to add some extra security in case one of the mains wires get lose and touches the casing (fire/shock hazard). Either way medical equipment is grounded using thick ground straps and most certainly not floating.
Using an isolation transformer to float a circuit or test equipment is bad practise and should not be done because there are numerous way this can lead to potentially deadly situations without being obvious to the operator. People will probably disagree with this but then again there are those who say smoking isn't bad for your health.
  • Country: lt
« Reply #15 on: August 07, 2016, 11:12:35 pm »
To my knowledge, earth is carried though almost always. I consider carried earth default setup for any transformer unless stated otherwise. I strongly suggest to test for continuity on all isolation transformers before use - text labels and indications may be misleading.
As to transformer in question, Noratel IMEDe 150, see page 15 from manufacturer's brochure IMED medical PSUs
Also, as can be seen in pictures
Thus, my best guess is that input/output windings are completely isolated from earth. Earth itself is carried through.
Anyway, I will have a real thing to test and use soon. I will make modification inside transformer or make special cable to break earth on output.
True in literal term usage, but that is only nomenclature. "Neutral" can kill you, so why is it called "neutral"? I consider "neutral" equal to "live", because both comes from same transformer. Let's not go to linguistics of L vs N.
I was referring more to IEC C13 and C14 plugs/sockets - these have small letters L/N/E on them. Letters allows to identify and name wires w.r.t. IEC socket/plug.
My point is that these IEC connectors are "polarised" at least with naming convention L/N/E - irrespective of what is connected to actual pins.
« Last Edit: August 08, 2016, 04:44:08 pm by electr_peter »
  • Country: lt
« Reply #16 on: August 07, 2016, 11:43:25 pm »
I agree that isolation transformer can be very dangerous.  But where does this "danger" comes from? It comes from the fact that isolated output may be connected to mains referenced circuit in some way (via oscilloscope GND, for example) making it not-isolated once again !!! User of isolation transformer must take this into acount.
As mentioned, use of isolation transformer is considered a bad practise in cases when other methods are available. I personally use isolated HV probes for mains stuff.
However, sometimes you need to have equipment 100% isolated from mains. For DC power one can use batteries, but for AC power the best solution is isolation transformer. And isolation transformer which carries earth through is only "half isolated" - that means isolation may or will be breached in some non-obvious way.
You need fully isolated transformer - meaning no physical contact between any of L/N/E wires. Disconnecting output earth will guarantee this in above case.
"Earth" as such is meaningless term for single local isolated voltage source and single load. "Earth" wire that is not even connected to secondary winding (but connected to mains earth) has no business on output wiring for isolation purposes in a lab.
« Last Edit: August 07, 2016, 11:48:51 pm by electr_peter »
Offline neslekkim
  • Country: no
« Reply #17 on: August 08, 2016, 06:20:09 am »
Not going to do mains stuff, but this kicked me off:
Offline HighVoltage
« Reply #18 on: August 08, 2016, 08:47:33 am »
Good explanation, guys!
Thanks, that is what I expected.
I have a huge 5 kW insulation transformer in my lab.
It has the earth connected from the input to the output
But line and neutral are floating.
And yes, insulation transformers can be very dangerous.
« Reply #19 on: August 08, 2016, 04:03:13 pm »
Hi, I'm not at home for 2 weeks, so I can't do some testing.
Anyway, I will a real thing to test and use soon. I will make modification inside transformer or make special cable to break earth on output.
I think you bought one, if I remember well. If you make any modifications, please show us in this topic, as it is always interesting stuff. :D
  • Country: lt
« Reply #20 on: August 09, 2016, 07:03:57 pm »
Check my post here teardown-and-modification-of-noratel-imed-e-150-isolation-transformer
« Reply #21 on: August 10, 2016, 07:27:39 am »
Thanks, I will read ! :D
Offline neslekkim
  • Country: no
« Reply #22 on: August 12, 2016, 07:54:08 pm »
Got mine today, looks very good, thanks!
« Reply #23 on: August 13, 2016, 08:12:03 am »
Great, have "fun".  ;D  :-/O :-DMM
