Do you know what the outputs of the TV's supply were? I don't think a single bench power supply is going to do very much good in this case. There are usually quite a few different power rails in a TV, in a plasma you will have some above 200V going to the Y and Z sustain boards. One LCD I was messing with the other day had 6 different voltages coming from the power supply.
